Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
GB - LM-1 Digital WideBand Air/Fuel Meter Kit
Old Jun 30, 2004 | 07:09 PM
TWoody's Avatar
Default LM-1 Digital WideBand Air/Fuel Meter Kit
LM-1: Digital Air/Fuel Ratio Meter
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
• The instrument can sample and store the air-fuel-ratio and the other sensor data internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included software or any standard spreadsheet program:
**click for more detail**
• The standard LM-1 includes a Bosch wide-band oxygen sensor and cable, cigarette-lighter adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and manual. The LM-1 ships with a Bosch sensor, however, it can also function with other wide-band sensors, including Honda/NTK and VW sensors.
• Available accessories include auxiliary input cables, alligator-clip power cable, exhaust clamp, analog output cable, and Aux. input expander. Additional accessories include a dash-mountable display and AC adapter.
The LM-1 sells for $349, including the oxygen sensor (Bosch LSU4.2), 10' sensor cable, 10' power cable, serial PC cable, and software..
As a standing offer, Wires4Cars is offering this kit to Honda-Tech members for $310 plus shipping.
When ordering via the website, redeem coupon code 4bc473 for a $39 discount off your LM-1 purchase.
...and the new auxiliary input unit, the LMA-3, makes the LM-1 even more desirable, combining 5 internal sensors for capturing Manifold Air Pressure (MAP or Boost), Cylinder Head Temperature (CHT) or Exhaust Gas Temperature (EGT), RPM conversion (from a tach signal or inductive clamp), Acceleration, and Injector Duty Cycle (or Dwell).
Everything in one compact box - every signal data loggable through the LM-1.
I'm offering the package - LM-1 & LMA-3 together, shipped, for $540.
You need to e-mail or IM me to take advantage of this package deal.
Cheers,
Pick up a set of wires while you're there!
Cheers,
Modified by TWoody at 8:41 PM 9/27/2004
Modified by TWoody at 8:44 PM 9/27/2004
Old Jul 18, 2004 | 08:18 AM
MrBui's Avatar
Default Re: GB - LM-1 Digital WideBand Air/Fuel Meter Kit (TWoody)
how much for the aux hook up and the exhaust hook up?
Old Oct 4, 2004 | 10:27 PM
spoolin turbo s's Avatar
Default Re: GB - LM-1 Digital WideBand Air/Fuel Meter Kit (n20need4vtec)
do you have a pic of the in car display unit?
Old Oct 5, 2004 | 05:03 AM
TWoody's Avatar
Default Re: GB - LM-1 Digital WideBand Air/Fuel Meter Kit (spoolin turbo s)
The display is built into the controller itself - so the whole thing would be mounted somewhere visible in the vehicle.
They are releasing a remote digital display shortly -
..and until then offer an analog display -
Modified by TWoody at 6:41 PM 11/24/2004
Old Nov 24, 2004 | 09:41 AM
TWoody's Avatar
Units in stock and ready to ship!
Old Jan 7, 2005 | 11:07 AM
TWoody's Avatar
New shipment just in - if you are tuning FI, a good datalogging wideband unit is a must have!
Cheers,
Old Jan 11, 2005 | 08:41 AM
racecarpete's Avatar
Do we get the new black model?
Old Jan 11, 2005 | 12:50 PM
TWoody's Avatar
Default Re: GB - LM-1 Digital WideBand Air/Fuel Meter Kit (SilverCivic2k)
All current shipments of the LM-1 are the black-cased model. There is no functional difference between it and the previous white-cased model - only the aesthetic change in the color of the molded plastic housing.
For those of you with LM-1's - do keep in mind that the unit is flash updateable, and that new firmware can be downloaded periodically from Innovate Motorsports website and flashed to your LM-1. The latest LogWorks datalogging software is also available from the same page.
http://www.innovatemotorsports...d.php
Cheers,
Old Jan 14, 2005 | 06:42 AM
Great seller. Thanks for the cookies.
Old Jan 17, 2005 | 12:11 AM
kazino42's Avatar
Just order one today, hope to get it soon.
Old Jan 27, 2005 | 02:50 PM
RCautoworks's Avatar
Default Re: LM-1 Digital WideBand Air/Fuel Meter Kit (TWoody)
Can you give me the link to your site for the cable that you need to read rpms with this controller. Looked but did not know which one I need.
Old Jan 29, 2005 | 09:35 AM
dester223's Avatar
Default Re: LM-1 Digital WideBand Air/Fuel Meter Kit (90blackcrx)
http://www.innovatemotorsports...age=1
that is what you need. Aux #2
Old Feb 2, 2005 | 08:05 AM
TWoody's Avatar
Default Re: LM-1 Digital WideBand Air/Fuel Meter Kit (dester223)
New LM-1 Accessories from Innovate Motorsports now available at Wires4Cars.
Window Mount - finally, a mounting solution for the LM-1 affording easy visibility of the LM-1 unit while road tuning your vehicle:
MTS Carrying Case - durable plastic case with foam interior. Custom cutouts to provide the best possible protection for your LM-1 and accessories:
Autronic ECU Interface Cable - modified analog output cable that includes some active circuitry to precisely match the input expectations of the Autronic ECU.
Cheers!
Old Mar 3, 2005 | 07:51 AM
TWoody's Avatar
This pricing is still in effect
Old Mar 8, 2005 | 08:58 AM
TWoody's Avatar
Need one? I got 'em...
Old Mar 9, 2005 | 11:40 AM
fjt's Avatar
fjt
will this WB work with Uber?
Old Mar 9, 2005 | 05:04 PM
TWoody's Avatar
Default Re: (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">will this WB work with Uber?</TD></TR></TABLE>
Using the LM-1 auxiliary output cable, you can provide any device with an output signal, and programmatically control the voltage mapping for that signal. The auxiliary output cable is like $8 extra - so an inexpensive solution as well :-)
Old Mar 10, 2005 | 05:10 AM
fjt's Avatar
fjt
Default Re: (TWoody)
Can you give me a price with that cable youre talking about and the Window mount?
Shipped to San Juan, P.R. 00936
Also how much would it be with the carrying case?
Thanks
Old Mar 10, 2005 | 07:09 AM
TWoody's Avatar
Default Re: (fjt)
E-Mailed you with pricing.
Old Mar 10, 2005 | 09:30 AM
fjt's Avatar
fjt
Got it thanks..I will prob be ordering next week after i get paid.
Old Mar 15, 2005 | 06:28 PM
gen2integra2001's Avatar
ill have to get 1 within the week since im in the process of putting on my kit
Old Mar 17, 2005 | 11:14 AM
TWoody's Avatar
Default Re: (gen2integra2001)
Shipping in April!
The Innovate XD-1 Programmable Digital Gauge - integrates directly with your LM-1 to put that critical AFR display within easy view, while tucking your LM-1 safely out of the way.
Use coupon code d79e6e when ordering for $10 off this gauge - pre-order by the end of March and shipping is FREE.
The Innovate Standalone Gauge Kit couples the XD-1 with the LC-1 Lambda Cable - a complete standalone wideband controller built into a sealed cable.
Use coupon code 31e5a7 when ordering for $20 off this kit - pre-order by the end of March and shipping is FREE.
DualCamDan
Southeast (Sales)
Dec 14, 2010 09:14 AM
b18bturbo
Mar 3, 2006 05:02 AM
STHPERFORMANCE
Aug 16, 2005 08:36 AM
Rocket
Jun 16, 2005 09:21 PM
K24 Turbo EF
Jun 13, 2005 01:52 PM
