guys w/ jdm front install knowledge please help :D
Old Jun 30, 2004 | 04:52 PM
kuja's Avatar
Default guys w/ jdm front install knowledge please help :D
Hey guys, i have my hid jdm front end from passwordjdm. And i'm in the process of installing it, but i have a question about the install.. is it necesarry to replace the whole rad support, or just cut the top part off and weld that on.. The wiredspeedlad.com tutorial looks nice, and alls he does is cut the top part off both supports, and replaces the usdm w/ the jdm.. This is what my body guy suggests.
Now my friend that did his, tells me to cut the WHOLE usdm support off, and weld the jdm one on, that seems a bit overkill.. Are there any advantages or disadvantages in doing it either way.. the shop says replacing the whole thing, it might tend to sag after a while.
summary: cut/replace top rad support, or cut/replace WHOLE rad support
Thanks guys
Old Jul 1, 2004 | 01:45 PM
EnjoyTheRideDC2's Avatar
Default Re: guys w/ jdm front install knowledge please help :D (kuja)
when I did mine, I replaced the whole radiator support. Once the front end panels, such as the fenders and hood, are removed the support can be un-welded from the car with not tooo much of a problem. I dont think replacing it is overkill simply because the support matches up to the points well, mainly because it's made for the car.
I'm not sure if the bumper supports will correctly meet up and bolt in to the USDM spots. My advice is to change it, even if the USDM one is stronger (that's just my opinion). Good luck.
Old Jul 1, 2004 | 02:39 PM
spoonfed95's Avatar
Default Re: guys w/ jdm front install knowledge please help :D (EnjoyTheRideDC2)
With the cost involved with buying and installing a JDM front end, I would not skimp on any part. The USDM radiator support is different and should be completely replaced with the Factory JDM unit. I would find a body shop that won't try and take short cuts. You'll be happier if you only have to mess with this once.
Old Jul 1, 2004 | 03:13 PM
lapok25's Avatar
You can use the USDM but it is advisable to use JDM radiator support for conversion.
sikciv666
Dec 8, 2012 06:24 PM
chrisdavis6
Mar 24, 2007 01:49 AM
TodaR
Mar 13, 2003 07:10 AM
98ITR#0020
Mar 12, 2002 10:18 AM
Nick
Oct 24, 2001 09:04 PM
