pm6/b16a/turbo edit problem (code 20)
ok i was running a pr3 on a b16a, and today i went to plug in my pm6 to see if the socket was soldered in right. I turned her over (no gas and i unpluged the wires so it wouldnt start) the ecu checked out, but i get code 20, Electrical load detector. To my knowledge b16a dont have eld, so how does everyone with a b16a get around this?
thanks in advace
thanks in advace
yeah thanks, my question is the edl off the car body and not ready by the pr3 or is it part of the alternator?
thanks for the response, Vap, you always post **** and try to help everyone out
good mod
good mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Chemist »</TD></TR><TR><TD CLASS="quote">yeah thanks, my question is the edl off the car body and not ready by the pr3 or is it part of the alternator?
good mod
I don't understand your first sentence.
Thank you sir, I do my best to help out even when I don't know the answer.
good mod
</TD></TR></TABLE>I don't understand your first sentence.
the eletric load detector, does it work off the car body or is it a part of the motor (the b16a is lacking one off) basically if i plug back in the eld pin into my ecu will it get rid of this problem ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Chemist »</TD></TR><TR><TD CLASS="quote">the eletric load detector, does it work off the car body or is it a part of the motor (the b16a is lacking one off) basically if i plug back in the eld pin into my ecu will it get rid of this problem ?</TD></TR></TABLE>
I have heard that you can unplug it and get rid of the code but don't quote me on that. I have also heard that it runs off the electrical system, for example a loose ground.
P.S. Yes The Doors rock but they OWN Pink Floyd!
First off all i got to say is Echoes off Echoes is the greatest song, i would invest some time on downloading it, and beter yet its 18 minutes long
realy great song.
I think my battery is kinda dead, or if i plug in the edl into the pm6 it would maybe fix this (i though the eld was part of the motor not the chassis)
well hopefully ill have an answer tommorrow
realy great song. I think my battery is kinda dead, or if i plug in the edl into the pm6 it would maybe fix this (i though the eld was part of the motor not the chassis)
cool thanks for the info guys
i think with all this info in hand i can fix the this problem tommorrow
I owe you both a cold beer if your ever in NY
Is your b16 wired for vtec/knock/2nd o2? If so you removed the eld wire to put your 4 extra wires in. The pr3 dosent look for a eld, so when you put your pm6 in, it was looking for it. Ryan
yep.
you have a conflict in wiring between what your PM6 wants and your PR3.
PR3:
pin B19 = knock sensor
pin B5 = VTEC pressure switch
PM6:
pin B19 = ELD (located in your fusebox)
pin B5 = alternator
you can make a way to swap these connections when switching ECUs .. or, ive been told, you can just run the PM7 codebase which doesnt use the ELD system... BUT i dont think its anywhere near as up to date as PGMFI-NG30 .. so basically you need a way to swap the pins
are you using a RPM switch for VTEC when running the PM6?
PR3:
PM6:
pin B5 = alternator
