ignition problem
Old Jun 30, 2004 | 04:15 PM
TURBO's Avatar
Default ignition problem
I just swapped over a b16a3 with a b16a and now I have no spark. I used the same intake manifold, distributor and wiring harness.
I have no clue where to look first...
Old Jun 30, 2004 | 05:18 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: ignition problem (TURBO)
look at the grounds on the thermostat housing first. if they arent tight, the ecu will not power up.
Old Jun 30, 2004 | 05:47 PM
nwdave's Avatar
Default Re: ignition problem (boostedcivicsir)
I'm currently having an issue with no spark myself. Do a search for "no spark" in both the recent and archived threads, you'll find good info on things to check.
Some things to look at:
Fuses
Plugs
Wires
Battery
Distributor
Grounds
Old Jun 30, 2004 | 11:06 PM
TURBO's Avatar
Default Re: ignition problem (nw.dave)
I did a rearch, but nothing and checked out everything..Strange this is the car had spark before...could it be the distributor has gone bad?
GoSickemRobert
Engine Management and Tuning
Aug 3, 2011 11:07 AM
OneFire
Jul 3, 2010 03:09 PM
Ski11z
Apr 28, 2005 03:14 PM
CptCorN
Jan 17, 2005 06:33 AM
nwdave
Jun 30, 2004 03:10 PM
