RSR GTII silencer!!!!!! AHHHHHH HELP ME
ok ive been trying for the past like 2 hours to get this dam thing out.. ive tried pulling.. ive tried sanding.. grease.. other crap.. all i get is a bent silencer.. not comming out.. F*%K RSR when they give you the exhaust with the silencer in..!!!!
any help would be appreciated
I'm not sure what the piping looks like before the muffler but maybe try pushing something down through the exhaust to bump it out.
or
Take a coat hanger and bend it so it makes a "J" and then shove it down the silencer and try to pull it out. When the siliencer gets stuck on my exhaust i take a pair of vise grip plyers and clip it on the silencer and pull. Try heating it a little bit either by torch or if you have a bigger oven. When the metal gets hot it will expand and should be able to pull out easily.
or
ok ive tried vice grips/wd 40/grease/driving for about 30 min so it gets hot/hammer/screwdrivers/dremel to sand it down.. etc etc etc.
got it out about 1/4 of an inch tops..
#1 i talked to JDMLifestyle and he told me to sand it down which i did.. no luck
#2 i might want to keep the silencer in case i really need it
#3 a coat hanger isnt anything close to strong enough to pull it out considering i put a vice grip on the dam thing and i pulled as hard as i could and used my body wight...
i got about an inch to go.....
Go find a wide empty space, and gun the hell out of your car. Eventually the exiting exhaust gas will have enough velocity to push the silencer out. I had this problem with my old A'PEXi N1. I used a ratchet wrench as a hook to wiggle the silencer out. What a ******* pain in the ***.
Umm did you unbolt it? maybe the bolt is still attached... or go to a gym and grab some muscles to help you yank that thing out. good luck.
torch wont work trust me i spent 2 days trying to get mine out.
i used the following
hooked prybar to pull it out
torch
so many pairs of pliars and vise grips
a really strong guy.
hammer and screwdriver
wd 40
tire shine
some really greasy ****
and none of them worked til i used that bit on a drill and it slid right out like it was nothing
torch
wd 40
tire shine
Did you try taking the screw out?
J/K. Did you try pushing one end in? Get it to tilt a little. Maybe you can get a better grip on it.
