D15B swap into a 4th gen civic/crx?
I was looking at this motor at this web site and it says with some work you can put a D15B in the 4th gen civic/crx. It doesnt come with transmission so how would that work since the stock transmission is cable and the D15B is ment for a hydrolic clutch? How much work would required and is it expensive? Thanks for any info.
u can use your stock tranny because it a d-series just like the b-series how they use different parts like tranny different head and d tranny should hook up, i was gonna do it but there alot of work to be done such as activity the vtec change the obd-1 conversion and i think there other things to but shouldn't be hard, the only why i did not do it is because i do not have time to do it that i went with a zc
civicracer1993
Nov 7, 2003 05:40 PM
