Help me choose pistons.
Old Jun 30, 2004 | 08:20 AM
Witty's Avatar
Default Help me choose pistons.
I'm trying to start my rebuild. I need oversized pistons that will land me in the 12:1 to 12:5 compression range. What are my options. This will be with an LS crank and GSR head, head is not milled.
Old Jun 30, 2004 | 08:31 AM
Jon5240's Avatar
Default Re: Help me choose pistons. (Witty)
ctr pistons and mill the head
Old Jul 2, 2004 | 09:10 AM
Witty's Avatar
Default Re: Help me choose pistons. (Jon5240)
CTR's would put me over 12:5 expecially with head milled.
Old Jul 2, 2004 | 11:40 AM
SL0WEGG's Avatar
just ctr pistons. dont mill the head. c speed says it'll be about 12.6 to 1. right about where u want it. but thats with the stock bore. i dont think honda makes anything bigger than .25 over. but with the .25 over it yields about 12.7:!. if your going bigger than that than i would go aftermarket.
Old Jul 2, 2004 | 09:22 PM
crazyitr's Avatar
Default Re: Help me choose pistons. (boostedej1)
You'll be fine.
My bro has the same setup in a lsvtec.
No tune it spanks the crap out of a similar integra with a JDM Type R swap
This is on 93 octane
Old Jul 6, 2004 | 05:04 AM
Witty's Avatar
Default Re: Help me choose pistons. (crazyitr)
I do not want to use CTR pistons. What other choices do I have?
Old Jul 6, 2004 | 05:10 AM
Greenery18's Avatar
slap some jdm P30's on some LS rods... should give you 11.8:1 with the GSR head.
heres a nice link to try out different setups and see what C/R you get: http://www.c-speedracing.com/h...c.php
Old Jul 6, 2004 | 05:17 AM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
Default Re: Help me choose pistons. (Greenery18)
I say go w/ wiseco's, they are by far the best aftermarket pistons imo, check out the import builders comparison here:
http://www.importbuilders.com/pistoncomparo.html
Old Jul 6, 2004 | 05:31 AM
Wraith_G2IC's Avatar
I think the next pistions in line behind the CTRs in terms of compression are JDM B16 P30 pistons. I don't think they will get you in your target range though. You can check C-Speed or some other online spec sites to see aprox compression.
Old Jul 6, 2004 | 08:11 AM
Default Re: Help me choose pistons. (Wraith_G2IC)
if anyone is curious where the speed compression calculator is, its here:
bakomack
Jul 18, 2010 10:37 PM
The Up Garage
11
Apr 8, 2006 12:32 PM
dwn-shift
Jun 24, 2003 07:19 PM
JDubya
Feb 21, 2003 09:56 AM
