What is this?
What is that large line that runs just behind the engine and over the blue vacuum line? It runs down in front of my tranny and then just stops. Its a pain in the *** and I just want to take it out. Can I?
edit.. haha
i've been working on my car too much... my brian is kinda fried. hehe LOL
that is the clutch cable. I used a DA one in my ef hb gsr. Try running it under the IM. In my case it worked out better & much cleaner look
Modified by Charlie Moua at 11:34 AM 6/30/2004
It is "not" a speedo cable!! The car uses a cable clutch and "thats" the cable that connects your clutch pedal to your transmision. If its in the way a bit, just use some zip ties and fassten it lower to the fuel rail so its out of the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by az17xscrub »</TD></TR><TR><TD CLASS="quote">if you have a cable tranny, it's the clutch cable. do not take this out</TD></TR></TABLE>
After reading the description again, that is what it is, clutch cable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
I concur.
</TD></TR></TABLE>I concur.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">I dont think mine is connected to anything.
Are you able to shift into gears?
</TD></TR></TABLE>Are you able to shift into gears?
Are you able to shift into gears? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">Yeah, I dont think it is. It just goes down in front of the tranny, and stops, right behind my radiator hose.</TD></TR></TABLE>
Do you have a hydro tranny conversion or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilGreenMachine »</TD></TR><TR><TD CLASS="quote">
Do you have a hydro tranny conversion or something?</TD></TR></TABLE>
I doubt it since he has a ZC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">Its a ZC, Si tranny. Drives fine.</TD></TR></TABLE>
In that case, it is your clutch cable and if it wasn't hooked up to anything you wouldn't be able to shift gears.
In that case, it is your clutch cable and if it wasn't hooked up to anything you wouldn't be able to shift gears. </TD></TR></TABLE>
yup. you got us on this one. unless you have a 2nd clutch cable hiding somewhere that is actuating your clutch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX »</TD></TR><TR><TD CLASS="quote">
yup. you got us on this one. unless you have a 2nd clutch cable hiding somewhere that is actuating your clutch? </TD></TR></TABLE>
lol. I bet it's his racing scheme, "look man I'll race you even without my clutch cable hooked up".....
HA HA and going in reverse
</TD></TR></TABLE>HA HA and going in reverse
