p29 pistons in a d15b vtec
What kind of compression ratio would you get with p29 pistons in a d15b vtec.
i really dont know what the math is to find out. any help would be great thanks
this is what i know
1st that my head is the same a d16z6 except for the cam
2nd that my block is pretty my a vx block with different pistons
block
my bore is 75mm
my stroke is 84.5
head
d16z6 34.6
Piston
p29 7.2
Head gasket Thickness
D16Y8 - D16Z6 OEM 0.03700000
this is where i have the problem
Piston-to-Deck Height
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">If you are trying to change pistons in a 1.5L you will need to adjust for VX rods by subtracting 3mm (0.1181 in) from the deck height.</TD></TR></TABLE>
i dont know what to select or do cuz i heard that my rods are the same as a vx so i am lost. if select OEM D16Z6 - D16Y7 the cr is 12.831599855799568. if i select other and type in .1181 i get a low cr of 9.331992906601563
block
my bore is 75mm
my stroke is 84.5
head
d16z6 34.6
Piston
p29 7.2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxjon »</TD></TR><TR><TD CLASS="quote">i read in a few past threads that people say it would yeild high cr, i dotn get why they would say it then</TD></TR></TABLE>
i said 9.3 is right for a STOCK d15b
pistons can be wierd,
might have a bigass dome but if they sit lower who knows wtf compression you'll get..
you just need to find out your deck to height so you can get an accurate reading from that calculator
no use trying to figure it out without that.
i seen a few people write that it would yeild high cr but you have to use vx pistons in like a d15b7. i am not goign to take my motor apart and spend a **** load of money unless i find out everythign needed
DelSolDon
Apr 2, 2011 11:29 AM
SOHCEK-Turbo
Apr 4, 2007 05:24 PM
no_one_
Mar 14, 2005 05:54 PM
