ZC SWAP HELL Distributor Hell
For reference: I am using a 1991 crx HF wire harness with this DOHC ZC if that matters.
Okay all, here is my situation...I have the DOHC ZC blacktop with the internal cam angle sensor, therefore please understand that there is no external cam angle sensor for me, just a black plastic cover on where the sensor would be, saying p30. Anyways, so I wired it up, all wires matched except for one coming from the zc distributor which was yellow with a green stripe. I just ran that wire to one of the crx white wires and switched them around later on when it wouldnt work. I get the code 15...which is "engine output signal". So I ordered the 89 integra distributor after hearing that it would bolt up, well it does, but it lacks the two wires for the cam angle sensor due to integras having the external cam angle sensor. I currently am waiting on a 92-95 civic distributor hoping that it will mount up and not lack the two wires I need for the distributor to work.
I have achieved spark...but no fuel is going to the motor due to
the ecu cutting it off because of the distributor.
What am I doing wrong here? Am I right in assuming my distributor could be bad? Anyone have some detailed pics for me?
Please help me, im in dire need of my car running...Please
-Steve (confused and desperate crxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx-Racer4Life »</TD></TR><TR><TD CLASS="quote">For reference: I am using a 1991 crx HF wire harness with this DOHC ZC if that matters.
anyways if you have the dizzy with all 3 sensors and the ICM all in one, you wouldn't have a problem unless you switched the two white wires, since you switched the white wires, you might want to swap out the ICM(ignitor)
what color plug was your dizzy(white or grey)? for some reason i thought that the single dizzy for DOHC ZC's where obd1....i might be mistaken on this
It sounds like you have an OBD1 Distributor(i believe those were the only DOHC ZCs without the exhaust cam sensor) You need to use the teggy dizzy and get a cam angle sensor, have a nice day
Yeah they are the squarish ones...I think im just gonna go with the cam angle sensor and get an integra distributor and call it a day.
I sent you 2 PM's and 2 E-mail's carlos just now...Please help me out man with that sensor, I need it for tommorow. I am going to pay for overnight shipping!
-Steve
Please let me know.
-Steve
Please let me know.
h22_crx
Mar 19, 2006 12:20 PM
89civich22
Oct 17, 2005 05:50 PM
juanb
Oct 4, 2004 06:02 PM
Crxkustoms
Sep 14, 2004 07:31 PM
