dc5 and ep3 parts interchangability
Old Jun 30, 2004 | 06:13 AM
white_EP's Avatar
Default dc5 and ep3 parts interchangability
give your comment and thought about this....
*peace*
Old Jun 30, 2004 | 06:21 AM
Kal's Avatar
Kal
Default Re: dc5 and ep3 parts interchangability (white_EP)
what parts?
Old Jun 30, 2004 | 06:25 AM
white_EP's Avatar
Default Re: dc5 and ep3 parts interchangability (Kal)
just list all the part that interchangable
Old Jun 30, 2004 | 06:41 AM
civicvtec1ps's Avatar
Engine.
Sway bars.
rear upper strut bars.
mid hatch bars.
Seats.
Old Jun 30, 2004 | 06:50 AM
white_EP's Avatar
Default Re: dc5 and ep3 parts interchangability (civicvtec1ps)
does the susy interchangeble? cuz i got dc5 suspension and thinking to put it on the EP
Old Jun 30, 2004 | 11:55 AM
BlueIntegraBoy's Avatar
Yes, the suspension is interchangable. DC5, EP3, and EM2 have similar suspensions.
Old Jun 30, 2004 | 01:57 PM
alfonzo's Avatar
Default Re: dc5 and ep3 parts interchangability (BlueIntegraBoy)
not only are the engineand tranys interchangable ..but it is probably the easiest swap out there
Old Jun 30, 2004 | 04:38 PM
SIINSI's Avatar
Default Re: dc5 and ep3 parts interchangability (alfonzo)
I have a question... do the JDM DC5 Brembos fit onto an '04 EP3? Is it just the rotors and calipers that are needed?
TIA
Miguel
Old Jul 1, 2004 | 06:21 AM
stealthhatch's Avatar
Default Re: dc5 and ep3 parts interchangability (SIINSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIINSI &raquo;</TD></TR><TR><TD CLASS="quote">I have a question... do the JDM DC5 Brembos fit onto an '04 EP3? Is it just the rotors and calipers that are needed?
TIA
Miguel</TD></TR></TABLE>
i've heard the mounting locations for the calipers are different
Old Jul 1, 2004 | 06:58 AM
Halo's Avatar
Default Re: dc5 and ep3 parts interchangability (stealthhatch)
So the RSX seats are a direct bolt in ?
Old Jul 1, 2004 | 12:03 PM
Default Re: dc5 and ep3 parts interchangability (Halo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Halo &raquo;</TD></TR><TR><TD CLASS="quote">So the RSX seats are a direct bolt in ?</TD></TR></TABLE>
Yes
TIA
You need the whole hub.
Old Jul 1, 2004 | 07:31 PM
SIINSI's Avatar
Cool, thanks
M
Old Jul 1, 2004 | 07:43 PM
Type X's Avatar
The seats don't bolt right in
3 holes line up and one needs 2 be modded
Old Jul 2, 2004 | 06:09 AM
arctic-k20's Avatar
and the front struts have different mounting brackets for the brake/abs lines - the si is on the same side as the arm and the rsx is on the opposite sid of the arm
Old Jul 3, 2004 | 06:21 PM
civicmatt's Avatar
How about SRIs and CAIs? Will one designed for an RSX work on a civic?
Old Jul 4, 2004 | 01:14 PM
whiteDCfiver's Avatar
Default Re: dc5 and ep3 parts interchangability (civicmatt)
To my limited knowledge no, The base dc5 has a totally diff IM, the one from the old gsr's. Si has the same IM as the type s dc5. See but now where you have the same IM's you have different engine setups. To add to the list i know the shift **** from the base looks pretty good in an EP.
Old Jul 22, 2004 | 06:30 AM
0psi's Avatar
Default Re: dc5 and ep3 parts interchangability (whiteDCfiver)
So the 6 speed transmission swaps over with no modification as well?
BoBo Racing
Jan 10, 2008 08:51 AM
jdmland
Suspension & Brakes
Jun 7, 2007 01:33 AM
DA9Rood
Aug 25, 2006 02:18 AM
B00STidDc5
Oct 17, 2005 04:26 AM
SlammedBlueEM2
Sep 22, 2003 12:16 AM
