Rebuild stock GSR
sup!!!i just got a rebuild stock gsr 97 running with aem cold air intake and a new set of 4x NGK iridium 9 sparks
what should i upgrade next? list all you can, any suggestion?
Such a newbie post. A) did you rebuild you're car with anything other then stock internals? B) What all got replaced in the rebuild? C) What type of power gains do you want D) what type of income do you have E) Can you do the work/modifications yourself?
Edit: F) why dont you research some of the different options out there and then decide for yourself what to do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxenhuh »</TD></TR><TR><TD CLASS="quote">Dont be a Jerk
Assume what he wants to do</TD></TR></TABLE>
He wasn't really being a jerk, they're all relevant questions. Even the "such a n00b post" quote really wasn't that out of line, seeing as he IS a n00b
to yeegsr:
If you want to make REAL power, I'd go turbo all day, every day. THAT can be your NEXT mod, IF you have the $.
otherwise, follow the advice already mentioned:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrMartin »</TD></TR><TR><TD CLASS="quote">header, exhaust, clutch and flywheel......maybe skunk2 manifold along with some camshafts </TD></TR></TABLE>
Assume what he wants to do</TD></TR></TABLE>He wasn't really being a jerk, they're all relevant questions. Even the "such a n00b post" quote really wasn't that out of line, seeing as he IS a n00b
to yeegsr:
oh well u got aint got nothing to say that can help..then thanx anyway....rebuild im assuming that's you're a pro...so good for you....i dont know so i ask if u dont like dont answer..
crawdad689 i got a dragz turbo waiting to install...wat should i upgrade along with it...that dragz get my stock 185 to about 280-300 at flywheel...im thinking of upgrading cam shaft and adj cam gears...and leave the piston along with low boost of 6-8 psi, is that sound ok to you? any suggestion plz feel free to post..thanx...i dont mind if i got insulted
tub_sephiroth
Mar 28, 2005 05:58 PM
