1998 Honda Accord EX 4-Door Spark Plugs
Old Jun 29, 2004 | 10:31 PM
andrewhill87's Avatar
Default 1998 Honda Accord EX 4-Door Spark Plugs
Okay all, my car is a 1998 Honda Accord EX 4-Door and i'm just starting to do anything at all to it. I just bought it and would like to add a little to it. As a starter...lol, something very cheap...what are the best PERFORMANCE spark plugs? I realize this is like a complete waste because spark plugs won't make that big a difference but I wanted to know what the experienced mind's opinon was. Right now I'm using Bosch Supers. Hahaha, once again i realize this is tiny but just wanted to know. I want to know the absolute best spark plug for performance, as long as it isn't like $20 each. Thanks
Old Jun 29, 2004 | 10:36 PM
asnboi_512's Avatar
Default Re: 1998 Honda Accord EX 4-Door Spark Plugs (andrewhill87)
ngk-r's
Old Jun 29, 2004 | 10:52 PM
Default Re: 1998 Honda Accord EX 4-Door Spark Plugs (asnboi_512)
since that's not compatible with my car i don't think i'll buy them...
Old Jun 30, 2004 | 09:48 AM
phoenixitc's Avatar
NGK's? NGK's aret recommended a lot by tuners for engines that are not highly modified.
Old Jun 30, 2004 | 10:17 AM
sexynuts(.)(.)'s Avatar
get NGK's...they are the stock spark plugs and work best...only about $10 or less for set of 4...you wont notice a difference in performance by just replacing the spark plugs unless ur old plugs are broken, get NGK
Old Jun 30, 2004 | 10:21 AM
The_Todd's Avatar
Farts in the shower
Default Re: 1998 Honda Accord EX 4-Door Spark Plugs (phoenixitc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoenixitc &raquo;</TD></TR><TR><TD CLASS="quote">NGK's? NGK's aret recommended a lot by tuners for engines that are not highly modified. </TD></TR></TABLE>
Actually NGK=OEM for honda
If you are running a decent amount of power upgrade your ignition system (plugs, wires, ignition etc) other than that just use OEM.
Old Jun 30, 2004 | 10:51 AM
Filthy Focker!'s Avatar
Default Re: 1998 Honda Accord EX 4-Door Spark Plugs (VRDrvr)
Like most and yourself said, there is no such thing as a performance spark plug. I will probably get flamed for this, but you are wasting your money. Did some dyno test a while back and found that it does not increase hp at all. Hell, even sparkplug manufacturerer like NGK state that...
If you wish to see, go to http://www.ngksparkplugs.com/t...ry=US
fs
jgiacalone
May 24, 2017 07:08 PM
Johnnyrod310
Jul 8, 2016 07:24 AM
Jimmydean771
Feb 8, 2014 03:39 AM
coolrace05
Nov 29, 2005 02:39 PM
turbocrazy
Oct 29, 2002 12:02 AM
