Is there such thing as an Adjustible Shift Linkage and a Welding one?
Old Jun 29, 2004 | 10:13 PM
Luserkid's Avatar
Default Is there such thing as an Adjustible Shift Linkage and a Welding one?
I was talking to a friend of mine that im going to do a swap for and he was wondering what shift linkage i was going to use. I asked him what he ment, and he said if it would be a welded one or an adjustible. Now i asked if he was talking about short shifter and he said no.
Has anyone ever hear of a adjustible, or welded on one? The only shift linkage i know is what bolts on to the tranny and the shifter.
Old Jun 29, 2004 | 10:31 PM
JDMlyfestyle's Avatar
ive seen some ad on for Short throws to make them shorter or longer. but shift linkage... i havent heard ne thing about that. if there is id definately like to see it
Old Jun 29, 2004 | 10:43 PM
Cnote's Avatar
Default Re: Is there such thing as an Adjustible Shift Linkage and a Welding one? (Luserkid)
on 92+ civic, never heard of it
on CRX with B series they had so-called adjustable ones.....more like adjustable **** linkage
Old Jun 30, 2004 | 04:39 AM
TurboC53_4g63T's Avatar
It depends on the craftmanship of the person making the linkage.AZracemachine makes there own linkage from scratch for 88-91 civic. I have installed two and they have great fittment.
Old Jun 30, 2004 | 04:42 AM
Fobtions's Avatar
Default Re: Is there such thing as an Adjustible Shift Linkage and a Welding one? (TurboC53_4g63T)
theres no reason for it to be adjustable.
to my knowledge they make em one size for swaps in EF's. most companies swithced from the adjustable style , to solid style.
Old Jun 30, 2004 | 04:55 AM
91civicDXdude's Avatar
If you make your own shift linkage from a 90-93 integra, its a good idea to make it adjustable so you dont have to be so exact on your measurements.
cut the shift linkage and remove about a 3-4" section. on the cut end of one half, weld a nut. on the cut end of the other half, weld on a piece of threaded bar stock. thread the linkage into the other half and you have an adjustable shift linkage.
Old Jun 30, 2004 | 06:49 AM
Luserkid's Avatar
Default Re: (91civicDXdude)
So an adjustible linkage is for CRX/88-91 swaps huh? I should have posted this in the EF forum because also this swap is on a 91 hatch. Maybe if needed a mod could move to the right forum.
From the sounds of it an adjustible isnt as strong as a solid one right. So what shift linkage would be best for a B16 into the 91 hatch. Thanks.
Also does anyone have pics of an adjustible linkage?
Old Jun 30, 2004 | 07:04 AM
Default Re: (Luserkid)
I'll have a pic of the one from AZracemachines in a couple of days.The adjusable one can be hit and miss.I've made linkages for the b16 into a civic from TEG linkages and you only need to remove 1in. without the adjustablity.Works fine.Adjustables unlock sometimes.
Old Jun 30, 2004 | 07:10 AM
UNDER PRESSURE's Avatar
Yeah victor a welded shift linkage just means that they cut it and welded it back together to make it fit the EF. I've broken and bent a couple of welded shift linkages before, I'd recommend that you look for one out of a jdm crx. Your in cali I'm sure you could locate one no problem.
Old Jun 30, 2004 | 08:43 AM
Jester88Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">If you make your own shift linkage from a 90-93 integra, its a good idea to make it adjustable so you dont have to be so exact on your measurements.
cut the shift linkage and remove about a 3-4" section. on the cut end of one half, weld a nut. on the cut end of the other half, weld on a piece of threaded bar stock. thread the linkage into the other half and you have an adjustable shift linkage.</TD></TR></TABLE>
not to hijack the thread or anything but my 91 teg shift linkage is bent all sorts of ways and i don't know where to cut it to keep it functional...can you help me out and tell me where to cut the linkage ?
Old Jun 30, 2004 | 09:06 AM
Default Re: (Jester88Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jester88Si &raquo;</TD></TR><TR><TD CLASS="quote">
not to hijack the thread or anything but my 91 teg shift linkage is bent all sorts of ways and i don't know where to cut it to keep it functional...can you help me out and tell me where to cut the linkage ?</TD></TR></TABLE>
Where ever it's the straightest.
Old Jun 30, 2004 | 04:17 PM
Luserkid's Avatar
Default Re: (UNDER PRESSURE)
Hector, and everyone else. Would you guys recommend an adjustible over a welded or welded over adjustible? And from the looks of it either way it goes ill need to customize to put the shift linkage in huh?
civicsi0721
Feb 25, 2009 07:17 PM
honda4674
Jun 24, 2006 12:45 AM
lsvtec101
May 2, 2003 08:17 AM
hybridbmw
Jun 24, 2002 04:15 PM
