car wont start need help!!!!
my car will crank over but will not start. i have a gsr dash in my eg si and none of the lights are turning on so the fuel pump will not turn on. i do not hear the fuel pump prime at all. and i do not see the lights on the dash for the e-brake and battery, oil, etc. i checked all my fuses and they looked fine. if i have the key in the ignition to the on position it will continue to beep like it does when the car door is open. but when it is on the ON position it is suppose to turn off after so many beeps. the car worked before it just started to do this out of nowhere. i tried to jump start it but it wont send a constant amount of fuel in so it wont stay running and when it is, it will run for a few seconds if you call it running. the car radio works and the headlights work still. can anyone help me i need to send my car to the state ref tommorow and it wont run. i got it to work before by changing a fuse but it only worked once and didnt turn on after i turned it off. and it also went out on me once again and i pulled the wire cover off and it just started to work again. please i need help.
Freshsho
Dec 18, 2005 10:50 AM
mahatma
Feb 9, 2005 05:07 AM
tallblondkid
Jan 25, 2004 04:06 PM
