b16 swap in 94 si, throwing a code 10. Please help
My friend and I are doing a swap into his 94 si. The block is a b16a1, and the head is from a 2000 si. he is throwing a code 10, but his IAT sensor isn't on the intake manifold like I thought it should be. Any help on how to hook it up, and what parts I might need to order from Honda? Thanks in advance guys.
Brad
Brad
You have code 10 b/c the IAT sensor plug isnt plugged up to anything. Your going to have to drill holes and install the IAT sensor onto the B16 manifold like I did.
I am assuming I need the iat sensor for a 99-00 si, since that is the year of the head. Is that correct? I don't know if it makes a difference, but he is using a GSR ecu. Thanks for all of the help guys.
green 3gg
Sep 16, 2008 05:12 AM
TeamDOHCside
May 31, 2004 09:12 PM
