B16 ECU Question
Old Jun 29, 2004 | 08:12 PM
kagegod's Avatar
Default B16 ECU Question
I have a CRX DX and I'm doing the B16A swap in it and I was looking at a comparison chart(http://b16a.honda-perf.org/wiringb16.htm) of the ECU plugs and what goes into each slot and I noticed that for B2 on the DX it's for the tandem valve but it serves no purpose on the SiR ECU. Since I would have a pin there could I remove that and use it for one of the pins I have to add(i.e. B10/B12/A8/C8)?
Old Jun 29, 2004 | 09:08 PM
rsbad454's Avatar
Default Re: B16 ECU Question (kagegod)
if its not needed....you can depin and cut and resolder for use somewhere else.
Old Jun 30, 2004 | 01:22 AM
Hybridcrx469's Avatar
Default Re: B16 ECU Question (rsbad454)
Here is a good link for wiring up your ECU....As you can see, their are a few pins that you dont need. http://www.hondata.com/techwiringpw0.html. After my swap i have about 4 wires that i dont need anymore
You need some ECU pins? I might be able to get some for ya
let me know for what connector if you need some
Tippyman
May 13, 2007 02:02 AM
hybridmiklo
Sep 9, 2006 08:00 AM
Tippyman
15
Mar 28, 2006 10:18 AM
teknohatchie91
10
Mar 26, 2005 11:49 AM
Lightning Lover.
Nov 18, 2003 12:27 PM
