h22 Info please
Ok right now i have a h22 in my civic ex.
MODs include:
fidanza flywheel
mugen computer chip
cai by aem
greddy exhaust
apec v-tec controller set at 4800 rpms
after market clutch not shure what brand
skunk 2 cam gears
msd ignition
hot shot headers
My question is what else could i do other than spray that would give me a significant increase in torque or power. If changing some things i have now to better quality mods then so be it i just need your in put please?
MODs include:
fidanza flywheel
mugen computer chip
cai by aem
greddy exhaust
skunk 2 cam gears
msd ignition
hot shot headers
spend some bux on a quality header, engine management, intake manifold. get rid of your cat, if you havent yet. larger diameter exhaust. headwork, valvetrain, more aggressive cams, type s pistons, or even sleeve the block, and get some crazy high compression forged pistons/rods etc etc etc... search!
clean up the IM , one of the biggest problems with the H's
yes, true 2.5" exhaust would help a lot, dump the cat if possible,
NICE flowing header and good intake..
Do you eve have an exhaust system? That made a huge amount of difference in low end torque compared to riding open header. I suggest that immediately if you don't already have an exhaust system.
I am using 2.5 inch exhaust purchased from Kteller ^ up above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 »</TD></TR><TR><TD CLASS="quote">clean up the IM , one of the biggest problems with the H's
TRUE.. BUT WHERE CAN YOU GET A GOOD INTAKE MANI FOR AN H SERIES?
SOMETHING NOT TOO EXPENSIVE AND FUNCTIONS WELL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostin b16 »</TD></TR><TR><TD CLASS="quote">
SOMETHING NOT TOO EXPENSIVE AND FUNCTIONS WELL</TD></TR></TABLE>
i might have the answer to that here in a bit.
but in the meantime
you got:
venom, and GE that offer h22 manifolds
SKunk2 if htey get it ever done..
and a few others i think are out there
but in the meantime
you got:
To get more torque I recommend either stroking it or going with higher compression on different cams, or do all three. Use an h23/f22 crank and crower st2 and with type-S pistons. If you sleeve you can get forged internals and bore to 89mm for larger displacement. You can get a real header too. I have read good things about smsp, an-r, and prospeed.
read this link and check out people's setups/tq numbers to get an idea:
https://honda-tech.com/zerothread?id=691830
HTH
the Pirate
HTH
the Pirate
