1990 Accord EX, Taking off front brake rotor HELP! PICS
Old Jun 29, 2004 | 07:57 PM
RedRacerCivic's Avatar
Default 1990 Accord EX, Taking off front brake rotor HELP! PICS
I am stuck right here. I took off 3 of the 4 bolts that go into the hub from the inside(4th one is stripped). What else do I need to do to get the hub off so I can remove my brake rotor?
Sorrry for large pics, no time to resize them.
Modified by RedRacerCivic at 12:29 AM 9/27/2007
Old Jun 29, 2004 | 08:12 PM
Riceburner247's Avatar
Default Re: 1990 Accord EX, Taking off front brake rotor HELP! PICS (RedRacerCivic)
I'm guessing it needs to be pressed off if you can't find anything else to unbolt.
Old Jun 29, 2004 | 08:42 PM
david90's Avatar
He does have one more bolt to take out.
Old Jun 29, 2004 | 10:37 PM
Schmitey's Avatar
Default Re: (david90)
Yeah dude...not sure on the 90 to be exact but I'd say that bolt has to go. Vice grips are your friend, as is a good blowtorch!
And damn did you ever wear down those rotors!
Old Jun 29, 2004 | 10:38 PM
accordnut's Avatar
An idea is to drill out the bolt so the head comes off, then you can get the rotor off and deal with the remaining portion of the bolt.
Old Jun 29, 2004 | 10:40 PM
Schmitey's Avatar
Default Re: (accordnut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordnut &raquo;</TD></TR><TR><TD CLASS="quote">An idea is to drill out the bolt so the head comes off, then you can get the rotor off and deal with the remaining portion of the bolt.</TD></TR></TABLE>
If it comes to that see if you can't find a reverse threaded drillbit, that way you loosen the bolt rather than tighten it. Another thing you can do is use a dremel tool at high speed. After that use an easy out. If it plain doesn't work your only options are to get a new hub or use a helicoil.
Old Jul 7, 2004 | 11:41 AM
Just wanted to keep you guys updated, Those 4 bolts on the back do not need to be taken off, I brought the whole knuckle assembly to a shop and they pressed the hub off. I guess those 4 bolts are just there for decoration or somthing lol. Man I didnt know rotors on accords were such bitches!
Old Jul 7, 2004 | 12:24 PM
91AccordSE's Avatar
Default Re: (RedRacerCivic)
HONDA ACCORD ROTORS ---- The reason on-car brake lathes were designed!!!
Old Jul 7, 2004 | 08:52 PM
Conechaser's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedRacerCivic &raquo;</TD></TR><TR><TD CLASS="quote">Just wanted to keep you guys updated, Those 4 bolts on the back do not need to be taken off, I brought the whole knuckle assembly to a shop and they pressed the hub off. I guess those 4 bolts are just there for decoration or somthing lol. Man I didnt know rotors on accords were such bitches!</TD></TR></TABLE>
Those 4 bolts hold the wheel bearing onto the knuckle, they are not just there for decoration.
Patty
Mar 7, 2009 08:12 AM
Birdley42008
Oct 1, 2007 03:35 PM
deeweezy187
May 13, 2006 09:29 PM
EL Vap133
Apr 6, 2004 11:44 AM
KayOs
Aug 18, 2002 10:35 PM
