95 accord H22 Turbo, got a lil problem, need help!
Old Jun 29, 2004 | 07:51 PM
makinasvp's Avatar
Default 95 accord H22 Turbo, got a lil problem, need help!
Hey guys, what's going on! Hope ya'll can help me out with a little problem. My car is open downpipe for the turbo, but it smokes a lot... So I went to the shop today and purchased a Greddy catch can. I didnt have one, so i thought maybe the oil was doing that. I'm not sure though, need opinions from you guys. And also, when i switch from 1st to 2nd gear, perfect, but from 2nd gear to 3rd gear when I drive normal/regularly, it GRINDS, why?? from 3rd to 4th, no grinding, from 4th to 5th, no grinding. Only from 2nd to 3rd. I'm a little worried about my tranny. Help!
Old Jun 29, 2004 | 08:22 PM
ItzTw's Avatar
Default Re: 95 accord H22 Turbo, got a lil problem, need help! (makinasvp)
if it your valve cover breather that smokes a lot, you fired a piston ring (lots of blowby).
Old Jun 29, 2004 | 09:16 PM
The Destroyer's Avatar
The tranny prob might be your synchro's.
What color is the exhaust smoke. Do a compression test also.
Old Jun 29, 2004 | 09:35 PM
PrecisionH23a's Avatar
Your questions were pretty much answered, but I'll just answer to verify that these are you rpoblems.
1) Preludes have weaker ringlands. How much boost were you running? If it was more than 8psi and you were untuned, you probably cracked one.
2) Prelude synchro's are notorious for going bad. Put in some GM synchromesh and it should bandaid the problem temporarily.
clemsoncb7
Aug 5, 2012 01:33 PM
5speeder
Transmission & Drivetrain
Dec 11, 2011 06:40 PM
jdm_cd5_sir
Nov 19, 2008 09:36 AM
mrvang84
Jul 17, 2006 08:20 PM
makinasvp
Jun 30, 2004 05:16 AM
