90-93 integra Front Wheel vibrating problem Need a lil help from the HT Family
Old Jun 29, 2004 | 06:44 PM
integrabois1991's Avatar
Default 90-93 integra Front Wheel vibrating problem Need a lil help from the HT Family
Hello everyone my Cousin bought a 91 integra LS and he's been asking me the problem for like 2 months straight...Well I checked the wheels look good to me...check if everything was loose everything was nice and tight, and then took it to the wheel shop to get the wheels balance....So when I took on the freeway and hit it up to 80+ and all of a sudden sucker was vibrating and I was like WTH and I could think of anything I told my cousin to take it to a shop to get a alighnment and camber set....still same thing can anyone give me any ideas what it could be it I would be very thankful......I was king of thinking the wheel bearing but I thought it would make humming noises.....Thanks for your time and have a good day...
Raymond
Old Jun 29, 2004 | 07:04 PM
Lord Helmet's Avatar
Default Re: 90-93 integra Front Wheel vibrating problem Need a lil help from the HT Family (integrabois1991)
have you checked the tires throughly yet? look at the tires closely, look for odd shaping in the tire diameter. you could have a flat spot somewhere on the tire caused from a broken belt inside the tire. other things to check for: bent rims & loose suspension parts.
Old Jun 29, 2004 | 07:39 PM
XrcR6's Avatar
Did the wheel shop dismount the wheels from the car to balance them; or did they do it on the car (dyanmically)? Are the rims aftermarket?
If you're using aftermarket rims that need hubcentric rings (the rim centerbore is larger than the ~56.1mm Honda hub register diameter) and they balanced the wheels off the car, that may be the problem. They'll be fine on the balancer, but when you go to mount them, they may get put on a little off-center of the hub center causing the vibration.
A wheel shop should be able to get you the right size hub-centric ring if that is the problem.
Old Jun 29, 2004 | 08:28 PM
damn im gonna check that out I did check the tires...the look fine ...well I have a set of VOLK TE37's and then I put a set of GSR Swirleys to see what it would do I check both tires...but ??/ they look good the wheel shop dismount the wheels from the car to balance them but Im gonna check the hubcentic rings and see what that will do...but I do thank you all lot for you opinion I feel the love..hehe
soeurm
Jul 30, 2007 03:02 AM
4thgenner
Mar 23, 2006 06:19 AM
integrabois1991
Jun 29, 2004 08:27 PM
Cowboy
Nov 30, 2003 03:03 PM
type r 01-1063
Jan 27, 2002 07:55 AM
