90-93 integra Front Wheel vibrating problem
Old Jun 29, 2004 | 06:42 PM
integrabois1991's Avatar
Default 90-93 integra Front Wheel vibrating problem
Hello everyone my Cousin bought a 91 integra LS and he's been asking me the problem for like 2 months straight...Well I checked the wheels look good to me...check if everything was loose everything was nice and tight, and then took it to the wheel shop to get the wheels balance....So when I took on the freeway and hit it up to 80+ and all of a sudden sucker was vibrating and I was like WTH and I could think of anything I told my cousin to take it to a shop to get a alighnment and camber set....still same thing can anyone give me any ideas what it could be it I would be very thankful......I was king of thinking the wheel bearing but I thought it would make humming noises.....Thanks for your time and have a good day...
Raymond
Old Jun 29, 2004 | 06:44 PM
.:TNN:RumbleN:.'s Avatar
Default Re: 90-93 integra Front Wheel vibrating problem (integrabois1991)
Sounds to me like your axles are starting to go.... ??
Old Jun 29, 2004 | 06:49 PM
Default Re: 90-93 integra Front Wheel vibrating problem (.:TNN:RumbleN:.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:TNN:RumbleN:. &raquo;</TD></TR><TR><TD CLASS="quote">Sounds to me like your axles are starting to go.... ??</TD></TR></TABLE>
they look good no rips.......checked them too...I did'nt even here that clicking noise...
Old Jun 29, 2004 | 08:18 PM
acura69integra's Avatar
hey i accually have a 91 integra LS and had the sam problem... like the previos guy said my axles were bad... even though the boot wasn't ripped the axle was shot. then finally gave out. also when replacing that axel i went to napa and got an axle from them (it ran abut 68$ minus the core charge) and noticed it accually has a balancing weight on the axle, which mine on the car did not... i don;t know if this helps but good luck...
Old Jun 29, 2004 | 08:23 PM
Default Re: 90-93 integra Front Wheel vibrating problem (acura69integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura69integra &raquo;</TD></TR><TR><TD CLASS="quote">hey i accually have a 91 integra LS and had the sam problem... like the previos guy said my axles were bad... even though the boot wasn't ripped the axle was shot. then finally gave out. also when replacing that axel i went to napa and got an axle from them (it ran abut 68$ minus the core charge) and noticed it accually has a balancing weight on the axle, which mine on the car did not... i don;t know if this helps but good luck... </TD></TR></TABLE>
hmmm im gonna try it ....Thanks man I aprieciate it bro...
Old Jun 29, 2004 | 08:27 PM
AllmotorEH2's Avatar
If the axle doesnt work for you your may want to check all your ball joints and bushings on the sway bar ect.. make sure your ball joints are in good condition and have grease in the boots...
b16a1eg6
Apr 26, 2007 05:28 PM
hamburgler
Sep 19, 2005 06:42 PM
Hmoob_Lee_guy
Apr 7, 2005 07:53 PM
integrabois1991
Jun 29, 2004 08:28 PM
Cowboy
Nov 30, 2003 03:03 PM
