Video I took today of me boosting a little...
Check it out..
I was hitting a max of 8.7 psi.....
Don't mind the slow shifting.
I need to find a better site to host this from....AOLs server is slow.
I didn't want to go too crazy since it was in a residential type area.
I'll put up some better movies soon with a more steady camera and everything and where I can let it loose a little more.
Gauges are:
upper left pillar: boost
lower left pillar: EGT
left bezel: Oil pressure
right bezel: fuel pressure (not tapped into my fuel system yet)
http://members.aol.com/degradated/my.../shortrun.mpeg
Gauges are:
Would that be a check engine light I see? What's going on there?
nice!
(cable modem let me dl at 300k/sec...hehe)
Hey, nice video....with code 65...did you try pulling the o2 sensor inside the car....thats what i did and it worked...
Yes, that's a code 65 for the second oxygen sensor. I'm still trying to find a solution for that. I guess it'll be like that until I convert to OBDI when I get Hondata.
The only little problem i had is that i had to reconnect the radio somewhere else.
What size tires are you running?? Sounds like you peel out in first, second, and third!
And that is only 8.7 psi? Damn nice.
[Modified by MiraiZ, 7:09 PM 11/19/2001]
Hmm...I'd think that meant he had bad traction...not good
