faulty car i think
Old Jun 29, 2004 | 05:33 PM
B18C-VTI_R's Avatar
Default faulty car i think
hey can someone tell me whats wrong with my car, the abs, fuel and bootlight on dash board comes on for no reason. it flashes sometime not always and not all of them at once
Old Jun 29, 2004 | 06:12 PM
flip b18b's Avatar
Default Re: faulty car i think (B18C-VTI_R)
there might be a problem with the ground on youir cluster causing all your lights to go on? is anything else acting weird?
Old Jun 30, 2004 | 02:24 PM
B18C-VTI_R's Avatar
Default Re: faulty car i think (flip b18b)
not that i known of yet as i just got my car for least than 2 weeks
Old Jun 30, 2004 | 05:26 PM
miketegra's Avatar
The car is faulty, you should replace it.............
...........just kidding.....
Tell us a little more and maybe we can actually help you.....
Old Jul 1, 2004 | 03:28 PM
B18C-VTI_R's Avatar
Default Re: faulty car i think (miketegra)
what you what to know??
Old Jul 1, 2004 | 03:48 PM
Medek's Avatar
what we are asking of you is for more detail. for example what conditions is your car in when exhibiting these symptoms. does your vehicle do anything labeled "wierd" or unordinary when these dash lights flash, etc. etc. numerous things could be affecting those components or the guage cluster (dash). when your abs light goes on or flashes are there wird noises or excessive abs braking being engaged. sensors could be bad. many many things.
now in my own personal experience. i've had dash lights flash, not work at all, speedo needle drop, any many other annoying things from frying my guage cluster by accidentally reversing the battery terminals (stuck negative on positive and positive on negative when heavily stoned on budda) check your fuses and the underdash wires for anything that may have melted together or come loose. and consult & research.
EL TYPE R
Dec 22, 2016 12:28 PM
B16aEk4drbeater
Nov 17, 2012 06:14 AM
Nerz206
Jul 26, 2011 09:51 AM
RagingAngel
Dec 9, 2002 12:18 PM
