B18C1 Head bolted onto a B16A2 Block, Direct Fit?
Will a 96 GSR Head directly bolt-on a B16a2 Block? What Head Gasket Would you recommend ( Block is built for 9 to 1 compression)? What ARP Head Studs and Rod Bolts ( for B16A or B18C ) will I need to order? Thanks for any info.
it will bolt up...
any vtec head gasket should work
I'm guessing you'll need the gsr head studs
rod bolts would be for the b16 unless using a different sized rod
twistedimage
12
Feb 5, 2009 03:00 PM
packman5280
Apr 10, 2008 06:15 AM
jsull.
Jan 24, 2006 09:07 AM
supaman111
Oct 6, 2004 01:57 PM
