How to upgrade fuel on turbo applications?
Old Jun 29, 2004 | 02:15 PM
92civiclsb18a's Avatar
Default How to upgrade fuel on turbo applications?
What should I use when upgrading my fuel on a turbo application? I've heard of using a FMU and upgrade my fuel pump. Will this work or should I go another way?
Old Jul 3, 2004 | 02:11 AM
Its Just a CRX's Avatar
Default Re: How to upgrade fuel on turbo applications? (92civiclsb18a)
Fuel pump, Injectors, fuel rail, fuel pressure regulator and tunning
Old Jul 3, 2004 | 02:16 AM
Kendall's Avatar
Or if you're cheap and still want it to be good, just get properly sized injectors and a larger fuel pump, then have it tuned. The stock fuel rail is more than sufficient to support most low-boost to moderate-boost applications. And an aftermarket FPR isn't always necessary.
big juan
Oct 29, 2005 06:59 AM
zeroz
Apr 16, 2005 08:33 PM
jwcardy
Apr 4, 2004 02:53 PM
Brian_92GSR
Oct 25, 2001 11:27 AM
