D16Z6 head gasket and arp head studs
Old Jun 29, 2004 | 01:32 PM
ComputerJLT's Avatar
Default D16Z6 head gasket and arp head studs
I aquired a D16Z6 engine to but in my 90 civic si and i'm salvaging my ARP studs out of my A6 to go in the Z6.
My question is; what should i tourque the studs to in the Z6? i tourqued the a6 to 67ft/lbs but since the z6 gasket is 3 layer i didnt know if it needed more or less.
Also the engine i bought was put together with a new hg tourqued down it didnt run and then was taken apart. Is the HG still useable since it wasn't even on the motor long or do i need another one?
I know the composite or whatever A6 gasket cannot be reused under any circumstance but i didnt know about the Z6.
Old Jun 29, 2004 | 07:43 PM
fastcivicboy's Avatar
hah good luck man! bump
Old Jul 1, 2004 | 01:27 PM
Default Re: (fastcivicboy)
bump
Old Jul 1, 2004 | 08:53 PM
civichb95lnd's Avatar
Default Re: D16Z6 head gasket and arp head studs (ComputerJLT)
For the d16z6 tighten the all the head stud bolts to 22ft lbs first then tighten all head stud bolts a second time to 55ft lbs.
Old Jul 2, 2004 | 01:16 AM
Default Re: D16Z6 head gasket and arp head studs (civichb95lnd)
i'm using studs not bolts
and 55lbs is not enough =-O
i can hand tighten them to that!!!! (not really but 67 felt kinda weak for my A6 and the z6 gasket is the metal one and that doesn't compress as easily as the a6 composite one)
Old Jul 2, 2004 | 09:27 AM
senpai's Avatar
ARP specs for Y8 is 60ft-lbs with their moly lube
Old Jul 2, 2004 | 10:23 PM
sporkcrx's Avatar
Default Re: D16Z6 head gasket and arp head studs (maztur)
I'd be careful using the a6 studs for the z6, since the z6 studs have a separate part number compared to the "d16" studs.
Old Jul 2, 2004 | 10:43 PM
Default Re: D16Z6 head gasket and arp head studs (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">I'd be careful using the a6 studs for the z6, since the z6 studs have a separate part number compared to the "d16" studs.</TD></TR></TABLE>
thats funny; i ordered the d16Z6 studs from lightningmotorsports and the arp guy and the guy @ lightningmotorsports said they were the same
and they fit perfectly.
and i torqued them down to 75lbs as per someone elses instructions; they've ran like that for a while with the mls gasket and had no problems with a boosted motor. i torqued them in 4 steps 20 40 60 and 70; dont know if that was right but i had nothing to go by.
i guess i'll find out in a few days/weeks if it blows that i didnt do it right :-p
91efalex
Nov 26, 2011 05:48 AM
beana
Aug 13, 2008 11:57 AM
wfocrx
Apr 6, 2007 01:34 AM
Xemu
11
Aug 30, 2006 09:02 PM
ghettocrxsi
11
Apr 23, 2003 03:41 PM
