B16 Swap Issue
Just swapped a B16a1 into a 90 CRX Si. Here's the problem: If I leave the VTEC solenoid valve UNPLUGGED, the car starts and runs fine with a little fluctioation at idle. If I plug it in, the car will not start. If I plug it in while the car is running, It immediately dies.
VTEC SOL. PLUGGED IN: Get a code 15 ignitor (but it's not bad!) & doesn't run.
VTEC SOL. UNPLUGGED: Get a code 21 VTEC SOLENOID (obviously) & car runs.
I followed the HASPORT wiring harness instructions. Any thoughts?
bigtimegambler
14
Nov 12, 2015 08:32 AM
ExplicitSpeed360
Nov 17, 2005 04:19 PM
