TPS wires
I know the red/blue one is supposed to get .5 volts at closed throtle. I know the green and white one, is supposed to get 5.0 volts at wot. My question to you guys is: Where does the green and white wire go? I know its a 5 volt wire, but where does the other end of it run to? If it runs to the ecu, what pin and plug # is it? Thanks, you guys are great.
