DOHC ZC / with a CRX SI tranny ?
From: Murfreesboro, Tennessee, United States of America
I have a DOHC ZC in 91 CRX i wont to replace the hf tranny with an SI CRX tranny
what all do i need to buy and do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">an Si tranny.</TD></TR></TABLE>
and install it.
and install it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
and install it.
no you dont have to.. pop it in the trunk, cap off the axles and fill her up with lube!
of course, duh!!
and install it.
</TD></TR></TABLE>no you dont have to.. pop it in the trunk, cap off the axles and fill her up with lube!
of course, duh!!
of course, duh!!
You answer wasn't exactly all techy either.
of course, duh!!
</TD></TR></TABLE>You answer wasn't exactly all techy either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">actually. a 90-91 Si Tranny to be more exact.</TD></TR></TABLE>
89-91 88 was the only different year.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource »</TD></TR><TR><TD CLASS="quote">u can use stock
if u need new ones got to AUTOZONE i think they're like $50-60 with core each</TD></TR></TABLE>
yup. I think it does matter if you don't have an Si though
it really doesn't matter.
When i buy parts from autozone, i give them crappy ****. Like the time i needed another dizzy for my Z6, i gave them a 90 dx dizzy as a core lol. I hold onto the better stuff and get rid of my dx crap. Like when I did my b20 swap...i gave them a ripped dx axle (the long one....LOL) and a ford bronco axle.....LOL!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam »</TD></TR><TR><TD CLASS="quote">it really doesn't matter.
When i buy parts from autozone, i give them crappy ****. Like the time i needed another dizzy for my Z6, i gave them a 90 dx dizzy as a core lol. I hold onto the better stuff and get rid of my dx crap. Like when I did my b20 swap...i gave them a ripped dx axle (the long one....LOL) and a ford bronco axle.....LOL!</TD></TR></TABLE>
Haha i do that to since i have a crapload of Dx parts. Im allways givin them that wrong stuff back for a core.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer »</TD></TR><TR><TD CLASS="quote">so if i get a si tranny thats all i need
i dont need the si axles
or hubs i can use the hf one?</TD></TR></TABLE>
Yes You can use the old alxes.
From: South Bay, Torrance/Carson, CA, United States
Just curious. What's the matter with the 88si tranny compared to the 89-91 trannys. That's the tranny i'm using and it seems to perform just fine.
Nothing is really wrong with them, They just have a different Imput shaft Spline Count. I think the 88 is twenty and all the rest are 21. Thats the only difference between years most people dont wanna have to buy a new clutch so they opt for the 89-91.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VeeTekCrx »</TD></TR><TR><TD CLASS="quote">You have an Hf right now, so that means you have hf spindles. I don't thing the Si axles will fit because the hub hole is too small. </TD></TR></TABLE>
thats what i thought as well
i have a doh zc in a 91 hf with a hf tranny want to swap with si but i thought that if i change the tranny i would have to change the tranny and axles and hubs?
i just want to chang the tranny not axles and hubs.
but if i do have to change the axles do i have to chang the hubs
can some one tell me for sure?
The HF Axles Will fit in the Si Tranny. If You wanted to use the Bigger SI Axles then you would need to Swap you hubs to the bigger hubs. But YES you can use HF Axles with the Si transmisson As long as you still have the HF hubs. You dont need to swap the hubs unless you want to use a ZC transmission or go B series really.
thanks man,
And what do yall think
should i change my axles to the si
i dont think the zc will break the hf ones
and if i was going to change them how hard is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKPX »</TD></TR><TR><TD CLASS="quote">wait if you go a ZC transmition you have to replace your hubs too? for some reason i never knew that.</TD></TR></TABLE>
If you want to use the ZC Halfshaft And hell im not sure if theres anyway you can use that transmission witout using the halfshaft. Im not sure if it sits in the same spots as a Regular D- series transmission.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer »</TD></TR><TR><TD CLASS="quote">thanks man,
and if i was going to change them how hard is it?</TD></TR></TABLE>
Its not Very hard Of Course you need the new Axles. And then you need the Steering knuckles of a Si. Removing the steering knuckles is pretty easy. You take of the upper ball joint and the lower ball joint and its out. But i really dont think the ZC will break the Hf axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MENACE »</TD></TR><TR><TD CLASS="quote">Nothing is really wrong with them, They just have a different Imput shaft Spline Count. I think the 88 is twenty and all the rest are 21. Thats the only difference between years most people dont wanna have to buy a new clutch so they opt for the 89-91.</TD></TR></TABLE>
Sorry for hikaching the thread. but yah i did notice that on ebay they sold a separate exedy clutch for the 88's.
do you have the zc haft shaft if you don't have one do you know how does. i need it asap................
Modified by sleeperstd91 at 4:50 PM 7/7/2004
