To h22 owners with with auto tensioners
Old Jun 28, 2004 | 09:00 PM
LUDERH22's Avatar
Default To h22 owners with with auto tensioners
does your belt vibrate between exh cam and crank when it is beeing reved up? and is it ok if the timing belt is sitting about 1/16 of an inch of of the cam gears. its been like that since intalled and hasn't moved for the past 300 miles what do you guys think??
Old Jun 29, 2004 | 07:21 AM
Joon525's Avatar
Default Re: To h22 owners with with auto tensioners (LUDERH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LUDERH22 &raquo;</TD></TR><TR><TD CLASS="quote">does your belt vibrate between exh cam and crank when it is beeing reved up? and is it ok if the timing belt is sitting about 1/16 of an inch of of the cam gears. its been like that since intalled and hasn't moved for the past 300 miles what do you guys think?? </TD></TR></TABLE>
I've never run my car with enough covers off to see if the belt vibrates between the exhaust cam and the crank.
As for the 1/16" and the cam gears....do you mean that it's 1/16" away from the edge (as if it's on its way to falling off)?
Old Jun 29, 2004 | 08:40 AM
LUDERH22's Avatar
yes but its not moving any further
Old Jun 29, 2004 | 10:56 AM
Old_Nocturnal's Avatar
At a few RPMs over idle, it is normal for the belt to vibrate on the "long" section of the belt. It should be pretty smooth at idle, though...
With the motor off You should be able to move the belt approx. one inch left to right between the crank pulley and the exhaust cam
Old Jun 29, 2004 | 11:12 AM
LUDERH22's Avatar
yea thats kool man but what do you guys think about the timing belt sitting about 1/16 of an inch off of the cam gears?
crxaddikt
Jun 4, 2012 12:18 PM
slammin86
Sep 24, 2008 04:28 PM
TurboB16A300Hpteg
Jun 20, 2008 07:45 PM
redlseg
Apr 20, 2005 07:07 PM
