Just got my Azenis, what Psi?
Old Nov 18, 2001 | 01:34 PM
Double 0 Seven's Avatar
Default Just got my Azenis, what Psi?
What psi should I run on these Azenis? The car is just for street. Thanks
Old Nov 18, 2001 | 01:53 PM
ITR111's Avatar
New User
Default Re: Just got my Azenis, what Psi? (Double 0 Seven)
what size?
Old Nov 18, 2001 | 04:51 PM
fangtl's Avatar
Default Re: Just got my Azenis, what Psi? (George Knighton)
I, like George, run 215/45/16s. I run f/r 35/34.
Old Nov 18, 2001 | 06:31 PM
yoshi234's Avatar
I shoot brides
I got 205/50R15s and run 33F/31R for streets.
Tryed them out at the autoX today.
1st run: 36/36 - <u>major</u> understeer! (93.xx sec)
2nd run: 35/39 - better but still understeered (91.xx sec)
3rd run: 35/41 - even better but still understeering (90.1x sec)
Overall these tyres are pretty good considering they are street tyres, but no where near the V700's!
yoshi - who wanted to try 35/45
Old Nov 18, 2001 | 06:43 PM
Cheap Bastard's Avatar
New User
Default Re: Just got my Azenis, what Psi? (yoshi234)
Hey yoshi234,
Were you out at Hollywood park today. I stopped by and saw several Hondas. You must have been the guy with the EBP Si with Azenis.
CB
Old Nov 18, 2001 | 06:47 PM
Hybrid ctr's Avatar
Default Re: Just got my Azenis, what Psi? (Cheap Bastard)
Hey yoshi234,
CB
yoshi has an itr
Old Nov 18, 2001 | 07:04 PM
yoshi234's Avatar
I shoot brides
Default Re: Just got my Azenis, what Psi? (Hybrid ctr)
Thanks Hybrid
yes, I have an ITR and I was parked about 3 cars over from that black Si. Mine is yellow and had #405 on it
yoshi - who made a mistake and signed up as 'time only' and not EP. No trophy for me now
Old Nov 18, 2001 | 09:42 PM
Wet Nudl's Avatar
New User
Really? I always thought to prevent from "oversteering" you pump more air in the front. You should have oversteering pumping 35/41 with the rear tires all rounded up and all. Mabye the tire is not as grippy as you think it is.
Old Nov 18, 2001 | 09:47 PM
Babalouie's Avatar
New User
Default Re: Just got my Azenis, what Psi? (TypeRP)
I asked the local Falken motorsport rep the same question, and he advised 30/28psi F/R. That was for roadcourse work though, where the heat buildup after a lap or so will give you a big pressure rise...
Old Nov 18, 2001 | 10:37 PM
ITR111's Avatar
New User
Default Re: Just got my Azenis, what Psi? (Babalouie)
i'm running 29psi/27psi. for 195/55/15
Old Nov 18, 2001 | 11:06 PM
jetli's Avatar
New User
Where can i get a set of these Azenis from?
Old Nov 18, 2001 | 11:31 PM
nEoMuGen's Avatar
Default Re: Just got my Azenis, what Psi? (jetli)
Wait a minute......and 91.xx sec Autocross? Wow! That must be hella fun!
Old Nov 19, 2001 | 03:49 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
!yoshi - who wanted to try 35/45
hey yoshi, when i ran my wifey's civic si (dead friggin stock) in ES a month back, i ran my hoosiers on it. i had to run 38/50! to get it to oversteer. i think for general street driving you should have 2psi more in the front for general understeer safety.
Old Nov 19, 2001 | 04:44 AM
Jason's Avatar
http://www.onlinetires.com or http://www.vulcantire.com or at your local America's Tire...
I contacted Falken directly for retailers in my area...try that as well
Old Nov 19, 2001 | 05:34 AM
Rodney's Avatar
[QUOTE]I am not presenting my pressures as ideal for autocrossing because I have never autocrossed the ITR; however, I am having a difficult time understanding why the difference between a road course and autocrossing would upset the laws of physics....
....so I await a logical explanation of why it's different, if someone can do that!
QUOTE]
you lost me george. are you asking why people like myself run higher pressures in the rear when autocrossing?
Old Nov 19, 2001 | 06:20 AM
yoshi234's Avatar
I shoot brides
I would <u>not</u> run 35/41 out on a road course.
The autox course yesterday had lots of really tight decreasing radius turns. Thus I needed the backend to rotate easily, to negotiate the 20+ turns.
yoshi - who had his 1st "3 clean runs" yesterday
Old Nov 19, 2001 | 06:55 AM
ZygSpeed's Avatar
OK, I think I got it. When you change the air pressures as radically as Yoshi is saying, you increase the polar moment of inertia so much that the car acts like it's oversteering.
You're putting <u>all</u> the weight on the front wheels, making that the centre of mass.
George, there's no way you can change the polar moment or weight distribution of a car by changing tire pressures!
What happens (by changing tire pressures) is that the contact patch changes, thereby allowing you to have one end or the other with more relative grip than the other. Upping the tire pressure will decrease the contact patch, ... allowing that end of the car to "slip" more than previously (since the added pressure lowers the patch area, limiting or reducing the lateral grip available at that end of the car).
If you were able to change the polar moment of a car by fudging with tire pressures then there's be no reason to put the engine in the middle or the back of a car to achieve that end (polar moment/weight distribution).
In summation, Yoshi had the right idea in upping the rear pressure bias in order to induce rotation (otherwise he's be running those 225/205 combos, again). HTH
Old Nov 19, 2001 | 08:59 AM
Austin's Avatar
Default Re: Just got my Azenis, what Psi? (zygspeed)
At the local autocross I was running the fronts at 35psi, the backs at 39psi, got just the right amount of rotation for me...though I am still a "beginner" at the autocross scene, on the street I run 35F/33R. 215-45/16 on Mugen MF-10 +43mm with stock suspension, I now have "soft spots" on 2 of them, so they're sitting in the living room at the moment.
Austin
Old Nov 19, 2001 | 02:51 PM
Lots of different responses. I have 205/50/15, should I just go with the manuals recommended psi?
[Modified by Double 0 Seven, 10:17 PM 11/20/2001]
Old Nov 19, 2001 | 03:18 PM
fangtl's Avatar
Play around with it. That's how most of us deal with the "problem."
Old Nov 19, 2001 | 05:23 PM
Warren's Avatar
Wrong-Way Wang
Lots of different responses. I have 205/50/15, should I just got with the manuals recommended psi?
Looks like there's an "autocross" way and a "track" way!
Same way for both. I run more air in back than I do in front, even with 400F/600R spring rates.
Warren
Old Nov 21, 2001 | 11:03 AM
Doctor CorteZ's Avatar
try 10/90 , guys with corvettes love that ration
its called a what? its like this business up front,party in the back
where is stlb friedmont?
Tylers88
Feb 16, 2017 08:59 AM
IntegraR0064
Apr 22, 2006 04:13 AM
GreenMachineRex
Mar 16, 2005 06:02 PM
kkim
Jul 19, 2002 01:47 AM
maxQ
12
May 21, 2002 04:44 AM
