itr max revs
Old Jun 28, 2004 | 06:38 PM
akasen8's Avatar
Default itr max revs
hey folks need a little info on itr cams whats the maximum revs u can do on itr cams with valves, dual valve springs with max lift of 13mm, taitanium retainers,all of wich are JG Engine Dynamic parts and a b18c1 head, with a stock bottom end ?????????
Old Jun 28, 2004 | 06:53 PM
11psiTurboSI's Avatar
Default Re: itr max revs (akasen8)
I wouldn't go more then 9000rpm!
Old Jun 28, 2004 | 07:05 PM
akasen8's Avatar
now is that because of the stock bottom or the stock itr cams????
Old Jun 28, 2004 | 07:47 PM
akasen8's Avatar
bump!
Old Jun 28, 2004 | 07:52 PM
Kal's Avatar
Kal
Default Re: (akasen8)
both... you won't get much power after 9000rpm for the cams and the stock bottom end isn't the greatest. The crank will lose pretty much its balance to the pistons after.
AranLamb
Sep 21, 2012 05:19 AM
lsvtec101
Jan 13, 2009 05:37 PM
Charlie Moua
Mar 17, 2003 06:54 AM
bboychris
Aug 4, 2002 06:13 PM
redteg1
Mar 6, 2002 09:15 PM
