*best* Auto tranny?
Old Jun 28, 2004 | 05:56 PM
Jays91DXhatch's Avatar
Default *best* Auto tranny?
I know that doesn't make sense....lol....
But I'm putting a SOHC ZC into my GF's 91 DX Auto hatch and would like to switch to MPFI but also put in a better D series Auto tranny if it exists.
I'm not sure if they are all the same from 88-2000? I know the Manuals are different because the 92+ are hydro but shouldn't make a difference in the auto tranny?
Just looking to see if anyone knows of a better geared auto tranny...this one kinda shifts hard and lags.
Not switching it to 5speed either so that ain't an option and I don't want to hear it. :D
Thanks!
Old Jun 28, 2004 | 07:39 PM
Default Re: *best* Auto tranny? (Jays91DXhatch)
no Love for the Auto?
Old Jun 28, 2004 | 07:49 PM
LSVTEC 91 Civic's Avatar
Banned
Not to ***** your thread, but I'm looking for the same info. I've got a D15B2 auto tranny I want to strengthen for towing my other EF cross country... From what I understand its the torque converter that you need to worry about.
Old Jun 28, 2004 | 08:16 PM
4crx4me's Avatar
I started to do a little research into this swap myself. I gave up after finding out this bit of information.
I doesnt appear that you can use a '92 or later civic A/T in a a pre 92 civic because '92 and up civics use a two stage electronically controlled torque converter. And the 88-91 Civics use a one stage. (ECU is OBD0)
You would need an AUTO ECU from a '92 and up civic,( OBD1, BTW) with the two-stage solenoid outputs AND the wiring from the ECU to A/T solenoids plus their connectors.
Anymore questions hit me up. I'll tell you what else I found out, if I can.
Old Jun 29, 2004 | 05:07 AM
Default Re: *best* Auto tranny? (4crx4me)
That's shitty.
does anyone know if the DX and Si Auto trannys are the same?
Old Jun 29, 2004 | 08:16 AM
BAZ's Avatar
BAZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jays91DXhatch &raquo;</TD></TR><TR><TD CLASS="quote">That's shitty.
does anyone know if the DX and Si Auto trannys are the same?</TD></TR></TABLE>
I dont believe Si's ever came in automatic trim, at least here in the US
4crx4me's Avatar
Gonna have to sick to Pre-'92 civic A/T trannys here.
If your talking 88-91 Civics..... NO 88-91SI's had an A/T ...... They were 5 sp only.
Only DX, LX..........
Old Jun 29, 2004 | 08:18 AM
We had Auto Si's here in Canada!
I've seen them plenty. Unless people were lying..but I doubt it.
Old Jun 29, 2004 | 08:21 AM
4drEF's Avatar
Keyboard Humorist
Good luck finding an "strong" tranny.
I killed an auto tranny and found out that it's common for a plate inside the tranny to become unfastened and begin spinning around in there. That happened to mine. No gears worked except sometimes if you slapped it into reverse and returned to drive. Then it would go until you took your foot off the gas. Left me stranded.
I wouldn't tow anything with it very far.
On the other hand, I turned around and replaced that ttranny with a remanufactured tranny from Honda. I guess they got all the bugs worked out of it. I abused that thing for 160,000 miles and it wouldn't break! Never slipped or anything and I was MEAN to it.
Old Jun 29, 2004 | 08:27 AM
4crx4me's Avatar
Default Re: *best* Auto tranny? (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">Good luck finding an "strong" tranny.
Yeah, that's one of the reasons they didn't put them in the Si's, Hondas early A/T's sucked *****. They were notoriously bad. Couldn't handle any stress.
But I had heard the new ones have gotten better.
Yeah I wouldn't tow a bicycle with a Honda A/T car LOL
Old Jun 29, 2004 | 08:36 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jays91DXhatch &raquo;</TD></TR><TR><TD CLASS="quote">We had Auto Si's here in Canada!
I've seen them plenty. Unless people were lying..but I doubt it.</TD></TR></TABLE>
really? Ive never seen one. I've seen a 99-00 Sir Auto tho.. so maybe it's true.
Old Jun 29, 2004 | 08:47 AM
4crx4me's Avatar
You are correct, sir. According to my '90-'91 Canadian Honda brochures, ALL Civics in Canada had the option of A/T EXCEPT The STD, and the CRX Si.
Old Jun 29, 2004 | 12:05 PM
onefaazztcrx's Avatar
ok i have done this swap its in my g/fs 89 four door with the d15b2 tranny this swap sucks there isnt hardly any noticable gain but on another note the si crxes did come with the option of auto tranny here in the U.S. and the computer you will need for this swap is a ps9 and be ready to make a bracket for the vaccum shift selonoid for the tranny and you have to have it perfect or it wont shift right...but on the the questions about the tranny if you can find the si tranny its generally a good price on them.... so you can take them to a transmission shop and have them rebuild it like its an si tranny but they ask you for you vin # on the car so you will need the vin number and all that good stuff......in other words it sucks to do this swap and if you do it and you find a better way to do the tranny let me know thanks Jeremy 89 4 dr d15b2 block z6 head obd2 intake manifold with ls throttle body and still has no power due to tranny i believe
Maestro Kull
Transmission & Drivetrain
Oct 19, 2015 07:38 PM
1 Civic I
Feb 17, 2010 01:29 PM
dubzz24
Sep 27, 2007 08:04 AM
markyh
Mar 1, 2005 09:29 AM
DaNish
Dec 7, 2001 06:07 AM
