VSS Problems (did search, not what is happening to me)
Hey guys, im hooking up my VSS to an integra cluster in my 1991 CRX Si. Got it hooked up, and now I'm getting a Check Engine Light - on all the time, and the ECU is just sitting red, its not throwing a code at all. I read other posts and everyone else was getting a code still, and I am not. So does anyone have any ideas of what it might be??
Any help is appreciated
what year integra cluster? im guessing its a electronic speed sensor like the one needed in a jdm sir cluster swap? i did mine and had no problems. did you solder all the connections? and where did you run the wires from the vss? there are three, one power that goes to a switched power behind the cluster, one ground, i grounded mine on the vss itself, and then the signal which goes into the cluster and into the ecu, what ecu are you running? if its an obd0 ecu its pin b16, thats what it is on pr3s and pwos, im not sure if its on a single cam ecu, but it should be, also if u are converted to obd1 i have the pin for the vss in the car ill get it if you need it.
civichatch2307
Aug 7, 2007 07:06 PM
jdmbaby
Sep 29, 2005 11:03 PM
