quick quaife question
Old Jun 28, 2004 | 05:21 PM
MrBui's Avatar
Default quick quaife question
can i use a civic si diff bearing for a quaife in a gsr tranny? the bearings are the same but the thickness its 1 mm off... i think gsr was 80x40x17 and si was 80x40x18...could i use the si and get a thiner shim? or am i better off getting a gsr bearing? searched but couldnt find the answer
Modified by n20need4vtec at 9:11 PM 6/28/2004
Old Jun 28, 2004 | 05:36 PM
devnull's Avatar
GSR bearing...
Old Jun 28, 2004 | 08:24 PM
ustccsi's Avatar
Default Re: quick quaife question (n20need4vtec)
Either way you will have to shim it, to get the correct play. So its not to loose, or to tight.
Old Jun 29, 2004 | 06:00 AM
MrBui's Avatar
Default Re: quick quaife question (ustccsi)
so u think the si will work? i work at honda so i can get honda parts cheap
Old Jun 29, 2004 | 08:20 AM
MrBui's Avatar
BUMP
Old Jun 29, 2004 | 10:25 AM
Sliced Beard's Avatar
yes the si will work but you will have to shim the diff properly
EKtypeRhaTcH
Nov 20, 2004 04:27 PM
EKtypeRhaTcH
Nov 20, 2004 12:09 PM
BlackSi325
Oct 6, 2003 10:43 AM
