Need help with preformance mods for a 91 civic DX with D15B2
Old Jun 28, 2004 | 04:53 PM
RLD's Avatar
RLD
Default Need help with preformance mods for a 91 civic DX with D15B2
Hey All,
I am new too the the sport compact ind, we have a 91 civic DX with a D15B2 motor we are looking for some suggestions on what performance and susp mods would help this car, other than the obv and engine swap
Any suggestions would be greatly appreciaited.
RLD
Old Jun 28, 2004 | 04:58 PM
mr. carpenter's Avatar
Default Re: Need help with preformance mods for a 91 civic DX with D15B2 (RLD)
the first thing you need to do is an mpfi swap. start from there and then figure out where to go next but the mpfi needs to be done first.
Old Jun 28, 2004 | 06:11 PM
paybac4223's Avatar
Default Re: Need help with preformance mods for a 91 civic DX with D15B2 (mr. carpenter)
humm... i would go with a ZC swap you can get em for about 500 bucks...buy the time you do like 3 mods to that dx you can pay for the ZC.... i had the same engine...believe me its not really worth modding other than an intake unless you are going to rebuild the engine....you you can spray it till you blow it then get the ZC....
Old Jun 28, 2004 | 07:37 PM
busychild's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">the first thing you need to do is an mpfi swap. start from there and then figure out where to go next but the mpfi needs to be done first.</TD></TR></TABLE>
I actually thought the b2 motor held its own for as much as I beat on it. I stayed single cam and if I were to re-think it, I would go turbo d16a6 round 12-14lbs. Good luck. there is a ton of knowledge on HT. Search is your friend.
Old Jun 28, 2004 | 07:46 PM
Default Re: Need help with preformance mods for a 91 civic DX with D15B2 (busychild)
i beat on my b2 for 3 years. won class champion in autox. it's a tough *** little motor.
Old Jun 29, 2004 | 05:04 AM
busychild's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">i beat on my b2 for 3 years. won class champion in autox. it's a tough *** little motor.</TD></TR></TABLE>
What is your setup now?
Old Jun 29, 2004 | 06:11 AM
RLD's Avatar
RLD
Mods that ahve been done,
- Cold air intake
- 2.5 in exhaust
- APC SS muffler
- Coil over kit with springs , all 4 coners.
- Rear Strut support, upper
- Front strut support, upper.
I was going to get a 4-2-1 header for the car as well, infact ther is one for sale on this site, bt as I am a newbe, I can not make an offer on it.
This car is a purpose biuld car for competeing in AutoX, i would like for know to stay in the class that i am in (C Super Stock)
RLD
Old Jun 29, 2004 | 06:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by busychild &raquo;</TD></TR><TR><TD CLASS="quote">
What is your setup now?</TD></TR></TABLE>
now i'm running a z6 in csp.
Old Jun 29, 2004 | 09:19 AM
busychild's Avatar
I am not sure what your limitations are in your class, but I would say you have a bottleneck in the head. I would p&p, add motor mount inserts, swap a thinner HG, hondata IM gasket, z6 exhaust manifold w a larger collector, and balance stock injectors. Tune and experiment with tire pressures. this is just me. hope this helps.
david236kEG
10
Feb 6, 2009 05:28 PM
2fast4udude
16
Jul 23, 2007 09:33 PM
extreme90civic
Sep 4, 2005 11:30 PM
danny91crx
Feb 7, 2003 12:26 AM
