how do i fit 98 integras into my 91 hatchie?
i got a set of tan 98 integras and i'm trying to figure out how to make em fit in the hatch swaping brackets didnt work what the hell do i do?
integra whats? seats?
https://honda-tech.com/zerothread?id=623787
read the whole post cause the first guy says no but they will go in.
Line the seat (with integra rails) up with the front screw holes, just the inside (shifter side) screw will fit so use the screw in the hole. The outer one you will have to drill your own hole and use your own bolt and nut. The back hole on the inside is going to need a custom bracket or spacer something that is about 1" cubed. Basically it just needs to be about an inch tall and be able to fit a bolt through it. The outside back you will have to get a flat piece of metal at least ~4" x ~6" screw that down to the floor where the bolt for the seat will be centered then put the bolt in. That will pull the bend in the seat bracket flat but will be secure. If you want Ill grab some pics tomorrow.
springthemadcap
Apr 15, 2007 05:33 PM
quikhb
Oct 31, 2001 08:37 PM
