93 Honda Accord. How do I check?
My father inlaw has a 93 accord. It has a few probelms with it. Just wanted to get ideas on how to fix these problems he has.
1.)ABS light came on. Is there a way to check whats wrong? Does it also throw codes? If so how do I check it?
2.)Driverside window goes up but not correctly. It seems to be getting stuck on the mirror making it not able to go up all the way.
3.)Exhaust is wayyy loud. I'm guessing it has a hole somewhere. Can I just patch it up with some JB weld? Would that hold it or is there something else I have to use?
4.)Rough Idle with the AC. Can I just adjust the idle screw for this?
TIA for your help guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Powa »</TD></TR><TR><TD CLASS="quote">up</TD></TR></TABLE>
i think i told u earlier how to check abs light for wheel sensors ne way.. ill tell u again. jack up the front of the car and let it outta get that will tell u if its one of the front sensors and if the light doesnt come on then jack up the rear and manually push the wheel but u gotta spin it kinda fast. i just had the same problem.. the light comes on after u drive it a couple seconds but u turn it off and let it sit and it stays off. thats the easiest and quickest way i could find or think of to test the wheel sensors.. also when ur doin it if u find out what wheel it is try to go clean the magnets behind the rotors before u go out to buy a new sensor. it could just be the magnets. for the exhaust. go out and buy a new aftermarket exhaust make some power and stop bein cheap..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 16.45_stock_94accord »</TD></TR><TR><TD CLASS="quote">i think i told u earlier how to check abs light for wheel sensors ne way.. ill tell u again. jack up the front of the car and let it outta get that will tell u if its one of the front sensors and if the light doesnt come on then jack up the rear and manually push the wheel but u gotta spin it kinda fast. i just had the same problem.. the light comes on after u drive it a couple seconds but u turn it off and let it sit and it stays off. thats the easiest and quickest way i could find or think of to test the wheel sensors.. also when ur doin it if u find out what wheel it is try to go clean the magnets behind the rotors before u go out to buy a new sensor. it could just be the magnets. for the exhaust. go out and buy a new aftermarket exhaust make some power and stop bein cheap..
1.)No you didnt tell me earlier because this is the first time i'm posting about this problem.
2.)I will try to clean the magnets to check the ABS first. Hopefully thats the problem.
3.)This isnt my car, as stated above its my father in-laws car so there for I wouldnt put a new aftermarket exhaust.
4.)Thanks for trying to help out though.
</TD></TR></TABLE>1.)No you didnt tell me earlier because this is the first time i'm posting about this problem.
sorry i didnt read all of it someone posted a question just like that yesterday and the pictures looked the same.. i would buy a new exhaust.. welds rust out so it will just make a bigger hole. its worth it in the long run to get new exhaust.. aftermarket or not. does the light come on immidiately or do u have to drive for a couple seconds before it comes on..
if u dont move and the light comes on im not sure but if u gotta move its most likely sensors or magnets.
