zc half shaft problem.
Old Jun 28, 2004 | 11:53 AM
d357r0y's Avatar
Default zc half shaft problem.
I SEARCHED!
I'm in the middle of bolting up my zc/si hybrid tranny and i'm putting in the half shaft. I've matched the half shaft to other photos and it appears to be the correct one.
Anyway.. I can't make it bolt to the block!
the holes on the half shaft are about 1/2 inch too high, I put a pry bar on the shaft to push it down and I was able to get one bolt in, but now it's putting a lot of pressure on the differential.
Any suggestions? HELP!!!
Modified by d357r0y at 3:36 PM 7/8/2004
Old Jun 28, 2004 | 12:00 PM
4drEF's Avatar
Keyboard Humorist
Default Re: zc half shaft problem. (d357r0y)
So you don't know what half-shaft you have? Sounds like you got the wrong one.
Old Jun 28, 2004 | 12:02 PM
d357r0y's Avatar
Default Re: zc half shaft problem. (4drEF)
it does sound that way. it sure does look exact to every other zc half shaft picture though.
I dunno, i'm ready to grind it to make it fit
Old Jun 28, 2004 | 12:12 PM
JapJunkie's Avatar
u got the wrong half-shaft, it lines right up easily
Old Jun 28, 2004 | 12:59 PM
d357r0y's Avatar
Default Re: zc half shaft problem. (hOnDadiCt)
yep. I did. you are right.
anyone want to help me ID this so I can sell it and get what I need?
Old Jun 28, 2004 | 02:10 PM
Drake's Avatar
It might be an Integra half shaft. Also in the third picture you have there is an AT Stamped on the half shaft so maybe that might be the problem too. Because I know that automatic tranny's in general are larget then manual transmissions. Sorry I cant be much more help. Good luck man.
Jeramy
Old Jun 28, 2004 | 02:21 PM
d357r0y's Avatar
Default Re: (Drake)
Modified by d357r0y at 2:49 PM 7/8/2004
Old Jun 28, 2004 | 02:28 PM
4drEF's Avatar
Keyboard Humorist
Default Re: (d357r0y)
... and you feel free to the post the name of the dead beat that sold you that intermediate shaft as a ZC manual if he won't trade you for the right one at his cost!
Old Jun 28, 2004 | 02:49 PM
d357r0y's Avatar
Default Re: (4drEF)
.. and you know I will!
Old Jun 28, 2004 | 03:23 PM
Nerologic's Avatar
dude, ditch the half shaft idea its WAY expensive. I just used ZC inner joints and installed them on my dx/si axles and it worked like a charm, another thing you can use is the B series inner joints they also do the trick, but if ur going to stick with the half shat...good luck finding one for cheap...
Old Jun 28, 2004 | 05:23 PM
d357r0y's Avatar
Default Re: (Nerologic)
odd that you would mention using a long shaft.. I was at oreilly auto parts and they had a LONG shaft for a 4wd wagon that would fit.
Old Jun 29, 2004 | 12:59 AM
Nerologic's Avatar
ya the 4wd wagon shaft works, i remeber reading a thread that it does work, but its harder to find then the ZC, but i gues in ur case its easy to find
Old Jun 29, 2004 | 07:09 AM
Dwight Schrute's Avatar
sorry for the newb questions, but what's so expensive about the half shaft idea? i can get zc axels and the half shaft for 90shipped. is that a good deal?
Old Jun 29, 2004 | 08:29 AM
4drEF's Avatar
Keyboard Humorist
I found a halfshaft for you... $30. Check your pm.
Old Jun 29, 2004 | 09:16 AM
d357r0y's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">I found a halfshaft for you... $30. Check your pm.</TD></TR></TABLE>
Checked and replied!
Old Jun 30, 2004 | 01:31 PM
4drEF's Avatar
Keyboard Humorist
He's still got it.
Get back to me about it.
Old Jun 30, 2004 | 05:04 PM
d357r0y's Avatar
PM returned!
Old Jun 30, 2004 | 05:09 PM
mar778c's Avatar
Community Builder
Community Influencer
Others have probly already said this but you have the wrong half shaft. Is the tranny an SI?
Old Jun 30, 2004 | 05:15 PM
d357r0y's Avatar
Default Re: zc half shaft problem. (mar778c)
ZC/SI hybrid transmission with zc differential. Yes, the half shaft is from an automatic, i bought it from a HT member and didn't even look at it until i got ready to install it. For this guys sake, I hope he lives far away.
Old Jul 8, 2004 | 12:38 PM
d357r0y's Avatar
bump it up for some pics that might help.
Old Jul 8, 2004 | 12:43 PM
4drEF's Avatar
Keyboard Humorist
Daaang - Johnny still hasn't gotten back to you?
Old Jul 8, 2004 | 12:46 PM
d357r0y's Avatar
That is correct sir.
But, i'm not so sure I have the wrong shaft. look at the pics I loaded... the shaft sits high. The other zc shafts i've had offered to me over the last week or so all look exactly like mine.
Old Jul 8, 2004 | 09:57 PM
Nerologic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">That is correct sir.
But, i'm not so sure I have the wrong shaft. look at the pics I loaded... the shaft sits high. The other zc shafts i've had offered to me over the last week or so all look exactly like mine.</TD></TR></TABLE>
hey man why dont u just run SI/DX axles and swap in the ZC/Bseries inners?? i told u that a few days ago. If you do this, this will solve all your problems you are having now. Sure they will be unequal but u will solve the headache u have right now of trying to find a shaft that fits. I pushed 220+ to a ZC/si tranny and i ran "oem" axles with the zc/bseries inners and i had no problems the whole time i had the car
Old Jul 9, 2004 | 05:46 AM
d357r0y's Avatar
Default Re: zc half shaft problem. (Nerologic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic &raquo;</TD></TR><TR><TD CLASS="quote">
hey man why dont u just run SI/DX axles and swap in the ZC/Bseries inners?? i told u that a few days ago. If you do this, this will solve all your problems you are having now. Sure they will be unequal but u will solve the headache u have right now of trying to find a shaft that fits. I pushed 220+ to a ZC/si tranny and i ran "oem" axles with the zc/bseries inners and i had no problems the whole time i had the car </TD></TR></TABLE>
Actually, I could go to O'Rielly auto parts and they have a long shaft with integra sized ends on it. I know what I'm doing is a head ache. but the half of the reason I went with the zc transmission was the use of the intermediate shaft. I actually have it bolted up now (i had to cut the mount holes a little) and it's working fine. I'm going to get a 2nd shaft and see how it fits later. Thanks for the suggestion though.
Old Jul 12, 2004 | 12:15 AM
3rdgenh22's Avatar
hey guys i have an 89 si crx w/ a dohc zc in it and i honestly have been so confused for the past year and a half about the whole axle thing.... its actually not my car anymore because i sold it, but the dude who has it now is still having problems. if u could answer a few questions that would be great. How do i know if its a zc tranny or what kind of tranny it is? i tried to use the stock crx si axel but its a few inches too short and comes apart on the first turn u make. so we thought maybe we would need the intermediate shaft, my friend took his off his car and the dude tried to use it on his but i guess its got 28 splines on that one and wont fit. how many splines do the zc intermediate shafts have? and is it true that if the stock si axels fit then it isnt a zc tranny anyway? could someone plz clarify the whole thing about usin b series inners or whatever, if i do that what axel do i need? sorry for such a long post but i've been very frustrated!!
btw i did search thats really how i found this post.
