b18c5 build...high compression wonders?
Old Jun 27, 2004 | 10:32 PM
Anthonyl469's Avatar
Default b18c5 build...high compression wonders?
here is the setup:
B18c5
CTR std pistons
stock R rods
S2S2 cams
Toda Cam gears
Toda belt
Mugen Headgasket
92 GSR head
S2 Ti retainers and springs
Hondata S200
everything else is stock 2001 ITR
Should I have any troubles on 93 octane gas for an everyday street car? Also anyone wanna help me out on a pretty acurate compression ratio? ( what CR I will have)
Old Jun 27, 2004 | 10:39 PM
Rhetoric's Avatar
Default Re: b18c5 build...high compression wonders? (Anthonyl469)
That set up is going to probably yeild higher than 13.1.
I'm not sure if 93 will suffice.
I have a similar set up (b18c5,std ctr, s2s2, oem hgasket, stock head) on 91 ocatane Im at 15 deg. ig. timing.
Old Jun 27, 2004 | 10:50 PM
Default Re: b18c5 build...high compression wonders? (Rhetoric)
b17 gsr head tho not the 94+...still a Pr3...im thinking like 12.3-12.4
panykus
15
Sep 19, 2004 08:55 PM
Beave0101
Jan 1, 2003 06:35 PM
akhom
Oct 13, 2002 10:21 PM
tecnic1
Apr 5, 2002 07:45 AM
