What do you think? Nifty Pictures inside...
Old Jun 27, 2004 | 08:55 PM
BrokenLimits's Avatar
Default What do you think? Nifty Pictures inside...
I pulled off my B16 head today and found this: I hit 6k in 1st gear and she let go
Modified by BrokenLimits at 12:17 AM 7/9/2004
Old Jun 27, 2004 | 10:06 PM
87b16crx's Avatar
nothing but red x's guy
Old Jun 28, 2004 | 03:24 AM
Default Re: (87b16crx)
funny works for me on 2 computers...
Old Jun 28, 2004 | 05:06 AM
Jon5240's Avatar
Damn! Stock LS Rod?
You have LS/VTEC right?
I know you lost the B16A, but I don't remeber if you put the lsvtec in...thats nuts man
Old Jun 28, 2004 | 06:33 AM
Default Re: (Jon5240)
No this is the B16. The LS VTEC is going in now a little ahead of schedule.
I had stock internals on my B16 just bolt ons
Old Jun 28, 2004 | 06:41 AM
smnowell's Avatar
Default Re: (BrokenLimits)
Wow, that's pretty shitty. That motor must have really wanted to die if it self-destructed at 6,000rpms in 1st gear. Oh well, now that gives you a reason to throw the LSVTEC in
Old Jun 28, 2004 | 07:01 AM
Default Re: (b16a ferio)
haha yeah. Only thing I can think is I did damage 30k miles ago with a 70 wet...
Sucks that it went this soon. I had everything I needed with the exception of fuel management. So once again I go in to debt
You can see the rest of the pics here:
http://www.brokenlimits.com/20...t.htm
Old Jun 28, 2004 | 01:56 PM
smart monkey's Avatar
Default Re: What do you think? Nifty Pictures inside... (BrokenLimits)
wow looks like you misshifted into 1st and blew up the piston. is that what happened?
Old Jun 28, 2004 | 02:15 PM
Default Re: What do you think? Nifty Pictures inside... (smart monkey)
Nope, 6k in first gear and then boom
Old Jun 28, 2004 | 03:08 PM
1slowcrx's Avatar
was it raining it looks like you hydro locked your motor. i have never seen a rod bend like that all motor
Old Jun 28, 2004 | 03:29 PM
Default Re: What do you think? Nifty Pictures inside... (1slowcrx)
nope completely dry.
Old Jun 28, 2004 | 06:13 PM
.DOHChi
Guest
Posts: n/a
ouch, when u were spraying before did ur motor mess up??
Old Jun 28, 2004 | 07:52 PM
NSTY Z33's Avatar
Wow bro, something HAD to be in the chamber, extreme temp, or SOMETHING, i don't know, but it happened for a reason. It wouldn't just destroy like that at 6k for no apparent reason.
Old Jun 28, 2004 | 08:20 PM
Sack Master's Avatar
Default Re: (JDMCRXDelSol)
The only time I've ever seen stuff like that is when the piston was jammed up into the head. Did you have any clearence problems, heat issues, serious detonation, leaning out, anything?
Old Jun 29, 2004 | 01:11 AM
G U E C O's Avatar
ouch
Old Jun 29, 2004 | 07:12 AM
Default Re: (Sack Master)
nope, all stock internals so I am thinking clearance issues wouldnt be a factor. I used to spray a 70 wet on the motor about 40 thousand miles ago. So maybe I weekend it then who the hell knows...
Old Jun 29, 2004 | 01:52 PM
ferio 95's Avatar
there is no possible way that just a 70 shot wet would cause that. Only way that couldt have happend would be hyrdolocking, overreving, mishift, spray into redline. Freind of mine sprayed into redline for about 2 seconds on a ls motor on a 150 shot wet full stock motor, all it did was blow out three exhaust valves and caused the fuel pump to take a ****.
Someone about your story just dont add up. Was this motor bought used? Where there any fuel tuning on it?
Old Jun 29, 2004 | 03:08 PM
Default Re: (ferio 95)
It has an OBD1 Chipped P28 running a Mugen Program.
I bought the car used with 19k on it. Seriously I am telling everything about it. I have no idea why it went. I realize something didnt add up too. I am also exploring the possibility that someone put something in my gas tank. I may drop it and check it here shortly.
Old Jun 29, 2004 | 03:53 PM
UNDER PRESSURE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokenLimits &raquo;</TD></TR><TR><TD CLASS="quote">I am also exploring the possibility that someone put something in my gas tank. I may drop it and check it here shortly.
Dang someone doesn't like you if that happened.
Old Jun 29, 2004 | 03:54 PM
Default Re: (UNDER PRESSURE)
well I hope thats not it...
But I am worried it might be. Any suggestions for dropping the gas tank?
Old Jun 29, 2004 | 10:12 PM
ferio 95's Avatar
maybe it was caused by detanation or bad gas. Ive had a freinds motor take a **** similar to that one because the gas they pumped wasnt 93, it was tested at like 89. Also was the chip a JDM chip or anything like that? Reason being the fuel levels in japan are different than here. They can get 101 at the pump and its possible that the ecu was tuned for higher then 93 octane. how long have you had the ecu with the chip on the motor?
Old Jun 30, 2004 | 04:01 AM
Ive had that ECU Roughly 5k miles.
EH3forlife
Transmission & Drivetrain
Apr 11, 2012 11:47 AM
1junkycivic
May 19, 2008 02:59 AM
mikeycivic
Aug 31, 2006 06:05 PM
Steve-o
Oct 8, 2002 03:54 PM
RexB16
29
Feb 18, 2002 10:58 PM
