Car carnks but no start
Ok i did a search & came up with nothing.
I have a 91 accord lx 4 door.
Today i was out shopping & as i cam out the store the car started & i backed out of the parking & went to pull forward & the car just shut off. So i pushed it back into a space.
I tried waiting for a lil bit & tried starting it again, but no luck.
I checked my main relay, nothing.
I checked my fuses, nothing.
I even thought my gas tank sender was broken so i put 2 gallons of gas in. nothing.
The car cranks & wants to start but just keeps cranking & you car smell the gas.
All day the car worked fine & now it wont start.
<U><FONT COLOR="red">HELP</FONT></U>
What should i look for ????
lol, you know what, that has happened to me in the past, do you run any kind of aftermarket ignition system? or have you and its now been taken off? are there any splices under the hood? what is happening to you is a matter of loose wiring, its happened to me before, ****...check for loose wiring, loose plugs, check your spark plugs, it has to be something electrical...
uhm, lets see, have you checked your air filter? check that, see if its dirty? when a car doesnt crank properly it can be a whole manner of things, you just basically have to, with trial and error mess with basically everything under the hood to see if they are either fastened correctly or in working order...its hard to diagnose, unless of course some of our more advanced members can jump in here and lend a helping hand!
well i just went to try to start the car & i checked my plugs & i took 3 of them out & i saw no spark.
I tried to start the car while holding the gas pedal to the floor & nothing.
what else ???
what else ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK »</TD></TR><TR><TD CLASS="quote">Would pop starting the car work so i can atleast get it home ????</TD></TR></TABLE>
I wouldn't think so...if you're not getting spark on 3 plugs, then I would aim towards the dizzy.
inside...check for any corrosion on the 'runner' (I don't know what they are called, but there is a circular shaped disc that has a metal contact point to touch another metal contact point that then connects to your plug wires)
Also what condition are your plugs in?
Yes number 5...the inside of that for each plug wire attachment on the inside there is a metal 'runner' .
Also number 3 is the inside circular thing I was tell you, it is what makes contact to those runners
Well i just got back from the car & i tried to pop start if just for **** & giggles no luck
Well i also took off the dizzy cap & checked the rotor & its in great shape.
as i removed the cover under the rotor (#10 in picture). the coil had a redish brown powder on it.
As i tried to start the car i noticed a strong smell of gas & i can hear the fuel pump running so i know its got gas & no spark to burn it off.
So please tell me what can cause me to have no spark ?? should i replace the igniter ???
or what should i do ?
Coil is a very common failure..it gets too hot under the cap, thats why they moved it to external on the 92-93 models.
You can check this link for diagnostic info.
http://www.batauto.com/cgi-bin...5&pid=
