Clutch help?
I just did a swap and when i start the car and go to put it into gear it wont go and if i have the clutch to the floor and jam it into gear the car moves even if the pedal is to the floor
Do you think my cable is bad?
If not what could it be? help please
Any help?
If i push the arm up the whole way and let go it doesnt seem to fall the hole way down
And also i was reading you need to pull the arm up til it hits and the tighten the cable
So any help would be appreciated
damn nothing come on peeps help me out
I crank the car it runs great but when i push the clutch in to put it into gear it just grinds like the clutch isint doing anything
also when i tighten the clutch cable almost all the way up to where its has the lever up the whole way and push the clutch it just goes to the floor
I took out the clutch cable and it dont look broke but maby it is?
Anyone
Anyone
come on people help me before i have to take the tranny out tommorrow morning
So when i go to put it into gear it grinds bad if i jam it into gear or start it in gear it jumps
motoris a d16y7 that came out of a 96 mt lx
im using my old si tranny
-When i was swapping the tranny on the y7 i was just going to use the stock clutch/pp/fw
from the y7 but when i was putting the tranny in it wouldnt fit in the y7 pp hole it was bigger then the hole was.
So i swapped the clutch and pp from my old motor that the tranny was on and when i try to put it in gear i get this problem
Any help would be greatful
yea i have pulled the lever up to the top and tightened it down and still get nothing
also with the car running i pull the lever up by hand and i dont get anything
no drop in the rpms or anything
jesusjdm89
Nov 17, 2010 06:50 PM
