car idles at 750 fine few minutes later it drops to 500 and steering wheel shakes...why
If i adjust the idle to 950 or 1000 it idles better but some times it will idle at 1300 if i do this. i was wondering if anyone knows how to fix this? I tried to reset ecu and pull out iac and adjust screw and still same thing. Its not a big deal just a little annoying...
DEF
DEF
mine does it all the time, don't even worry about it. It's just power surges, kinda like when you turn the a/c on in a car that has it. Also, on older cars, the injectors, regulator fuel filter stuff like that , don't act right sometimes, so that can do it as well. No biggie! Race on!
yeah car runs fine...just didnt know if there is anyway to fix it. Other than that no problems with car now.
DEF
DEF
From: hittin corners so hard you can taste my rims..
a few things come to mind..
and they're trial and error.. some are cheap good mod's.. some cost money.
1 new motor mounts
2 clean IVAC
3 plugs wires, cap, and rotor.
4 have the alternator tested.
5 valve adjustment.
6 maybe a fuel filter.
i think motor mounts at 40 bucks a peice, and the valve adjustment, if you have the right tools, is pure labor.. they all add up, and can contribute a problem... i hope you get my point.
1 new motor mounts
2 clean IVAC
5 valve adjustment.
civicEX1995
Honda Civic (2006 - 2015)
Jun 15, 2013 02:34 AM
jacksonww
Oct 26, 2008 03:49 AM
