Would a OBD2 distributor work on 94 GSR Head
Old Jun 27, 2004 | 10:12 AM
integmester's Avatar
Default Would a OBD2 distributor work on 94 GSR Head
Would a OBD2 distributor work on a 94 GSR Head? What else would I need to make the OBD2 distributor work? Or does it just plugs in and works?
Old Jun 27, 2004 | 10:46 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
I think it would work if you cut off the connectors and hard wired it. I could be wrong, though. Anyone know for sure?
Old Jun 29, 2004 | 01:37 PM
SivikHatch's Avatar
Default Re: (MugenDude)
tt
Old Jun 29, 2004 | 02:11 PM
ramennoodles's Avatar
Default Re: (SivikHatch)
would probably work if using an obd2 ecu
Old Jun 29, 2004 | 02:13 PM
Kwuaymaikrup's Avatar
Default Re: (600gixxer)
It will work just fine. You just need to wire it properly.
-Ryan
Old Jun 29, 2004 | 06:19 PM
Blown90hatcH's Avatar
Default Re: (Kwuaymaikrup)
It will work fine. You will have to change the distributor plug though. The OBd1 gsr engine harness plugs are different then that of the OBD2. It will bolt to the head fine as well.
Jason
DC2_Legend
Nov 3, 2007 06:26 PM
Ti3d in
Sep 29, 2006 12:16 AM
1990hondaHF
Aug 31, 2005 01:50 PM
