Toda High Compression kit/rods with spec a cams
Old Jun 27, 2004 | 09:16 AM
alanb's Avatar
Default Toda High Compression kit/rods with spec a cams
will this work so that max cam advance wont result in valve/valve valve piston contact?
Old Jun 27, 2004 | 04:37 PM
fuck honda-tech's Avatar
Default Re: Toda High Compression kit/rods with spec a cams (alanb)
i would think that would be too much compression for the a`s ... add there head gasket.. and throw some toda killers in it
Old Jun 27, 2004 | 07:44 PM
Kal's Avatar
Kal
you can get the VTC killer cam gears...
Old Jun 27, 2004 | 10:11 PM
lube's Avatar
Default Re: Toda High Compression kit/rods with spec a cams (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">you can get the VTC killer cam gears...</TD></TR></TABLE>
I doubt he'll have any money left after he pays $1850 for those Toda rods
Old Jun 28, 2004 | 01:36 AM
G.'s Avatar
G.
Hi Alan, fancy seeing you here.
BTW I have decided to be a traitor to the cause and go f/i, I know it's a cop out but JRSC is being fitted on the 10th of July at Abbey M/S (I know Mark from all his Skyline work).
Old Jun 28, 2004 | 04:18 AM
alanb's Avatar
Default Re: Toda High Compression kit/rods with spec a cams (G.)
hi G-the ctr specific jrsc is limited to 5psi at present
vtc is the way forward now -killing it is now seen as retrograde , but one would have though toda do produce compatible kit
want to stay all motor at present
Old Jun 28, 2004 | 09:45 PM
lube's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alanb &raquo;</TD></TR><TR><TD CLASS="quote">
any time you go with a bigger cam, you lose some of your ability to move the cam around. it's not Toda's fault.
Old Jun 29, 2004 | 08:14 AM
alanb's Avatar
hi g yeh ur right about that query
the ctr forum is down so im posting the reply here
krucial7integra
Apr 12, 2008 05:34 PM
camlob
May 10, 2006 06:59 AM
5-lugHatch
Jan 30, 2005 04:58 PM
danny98r
Sep 23, 2004 07:14 PM
.doeboyfresh.
Apr 12, 2004 11:09 AM
