Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Cooling System Surge Tank
Old Jun 27, 2004 | 06:37 AM
C-Zero's Avatar
Default Cooling System Surge Tank
Can someone show me a guide w/ pictures on how to use a surge tank for a cooling system on a car?
Old Jun 28, 2004 | 10:53 AM
C-Zero's Avatar
Anyone?
Old Jun 28, 2004 | 10:55 AM
MattD@Stoptech's Avatar
Default Re: (C-Zero)
AKA c00lant overfl0w tank....
Old Jun 28, 2004 | 11:08 AM
Two_K Si's Avatar
Default Re: (El Pollo Diablo)
Here is a bling one from techno pro spirit http://www.stageoneimports.com...1B008
Old Jun 28, 2004 | 11:14 AM
.RJ's Avatar
.RJ
Default Re: (Two_K Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si &raquo;</TD></TR><TR><TD CLASS="quote">Here is a bling one from techno pro spirit http://www.stageoneimports.com...1B008</TD></TR></TABLE>
Wow, thats ******* retarded.
$230 for an aluminum can? Whats wrong with the stock overflow tank? Even if you wanted a better/metal can, then take a look at the circle track stuff.... probably pick something up for $50 or less.
Old Jun 28, 2004 | 11:25 AM
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
$230 for an aluminum can? Whats wrong with the stock overflow tank? Even if you wanted a better/metal can, then take a look at the circle track stuff.... probably pick something up for $50 or less.</TD></TR></TABLE>
Yeah, that's almost as bad as getting a JDM steeringwheel....
Old Jun 28, 2004 | 11:50 AM
C-Zero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">AKA c00lant overfl0w tank....</TD></TR></TABLE>
I Emailed C&R and thats not what it is.
It's to let pressure out of the system. I need guide on how to install one.
So its not an overflow tank.
Heres what he told me :
No its not like an over flow tank. The surge can does 3 major things. 1) Removes air from the system 2) helps prevent water pump cavitations 3) maintains a more even pressure in the cooling system. The radiator cap is on top of the surge can, there is a bleed line from the top of the radiator to the top of the surge can, there is a second bleed line from the highest point that coolant flow in the motor to the top of the surge can and then there is a -10 on the bottom of the surge can that goes to the suck side of the water pump. If you have any more questions feel free to ask.
MONTELIOUS
Honda Civic (2006 - 2015)
Dec 4, 2006 04:23 PM
life sux die
Honda Motorcycles
32
Aug 22, 2006 10:46 PM
85
Honda Motorcycles
Jul 10, 2005 10:21 AM
suffe
Jun 23, 2005 07:58 AM
98r879
Dec 10, 2004 04:23 PM
