Life of your fully built motors
hey i was just curious on how long your fully built motors last? with like 12:1+ cr, beefy cams and the whole 9. Without out beating on them everyday of course. Can anybody list there setup and how long they've had it in the car and how its been working out so far? power losses? problems?
my car isnt a daily driver anymore but my motor is still running as strong as ever after 3 yrs.
1 yr of DD and track racing
1 yr of occassional street drivin and track *****
1 yr of all out trailer queen track *****
the only reason its not in my car anymore is because i stepped up to my next motor which is a 2L.
Guest
Posts: n/a
the average life for a engine with forged pistons is around 40K miles
a built n/a engine usually last less than that, because of the inherent street that will be put on it due to the high compression and rpm
but if yu take care of it, and drive sabley, you can outlast that somewhat.
my setup im gonna do is b18c1, b18a1 crank, complete skunk2 head...stage 3 cams, valvetrain etc.....pnp...and atleast 12.5:1 maybe 81.5 pistons...forged internals, stuff like that...how long you think the motor would last on average if i only hit vtec on the occational weekend? anything wrong with my future setup? anything you would do better for a more reliable daily driver?
If you have a high horsepower engine, you should be tearing it down yearly...minimum. For inspection, new rings, bearings, etc...
Can't expect this stuff to last forever...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV »</TD></TR><TR><TD CLASS="quote">C1 81.5mm pistons 12.5:1 claimed CR actual CR 11.3:1
JUN 3 cams
bolt ons</TD></TR></TABLE>
Im thinkin about the same setup but with eagle 94mm crank, what do you think the realibility will be ???
JUN 3 cams
im not a huge fan of stroker kits due to the fact that i havent seen a significant gain with a stroker kit. sure they produce more HP and torque but from the little bit ive seen its been faily minimal. for a all out race motor id prolly do it. only if i was on a nationwide tour though. for the average enthusiast its not worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokenLimits »</TD></TR><TR><TD CLASS="quote">I did not want to hear this...I was hoping this motor I am building would last me a VERY long time...</TD></TR></TABLE>
then build it with all honda oem parts...or have a good builder build it..with all oem honda parts
well bottom wise anyways..top wise..i'd replace the ti retainers every 15-20k... but thats minor ****
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GeeZR »</TD></TR><TR><TD CLASS="quote">i thought u had to remove the squirters, cuz of clearance problems?</TD></TR></TABLE>
with 95 possibly, not with 92mm or 89mm
and you can bend them out of hte way instead of removing them completely. a friend, RIP, had a 95mm eagle setup...his S/N was Babydaddy if you want to look up some of his post...he might have talked about it some.............RIP Tim
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow. »</TD></TR><TR><TD CLASS="quote">...
and the eagle crank is 95mm, no?
whats wrong with eagle stroker crank?? its so fragile??, im planning to 82mm bore with 3.70 (94mm) eagle crank ,so it would be almost 2.0 L
Honestley if you can afford a build like you were talking about it lasting for 40 k shouldnt be an issue. A full season w/ daily driving isnt bad and is all I would do. If you want something to last for a prolong time look into a more basic itr conversion set up. Lower reving motor,lower compression honda parts.
