Need new Tranny?
Old Jun 26, 2004 | 11:06 PM
Blue10karat's Avatar
Default Need new Tranny?
I have a 91 Accord LX automatic. My green S light had been blinkin for a while and my speedometer wasnt working...Now the S light stays on and my car will not change gears. Its happened b4 but then the light went off and the car rode fine...Now its on again and will not go off...I can start from D4 but car drags so I have to start at D1 and change the gears like a straight drive almost...You guys have any suggestions. I dont think I need a new tranny since it happen b4 and then started working fine....HELP PLEASE.
Old Jun 27, 2004 | 06:04 AM
Mike813's Avatar
Default Re: Need new Tranny? (Blue10karat)
when something blinks usually its a trouble code... get it checked and report back the problem or code...
Old Jun 27, 2004 | 07:53 AM
bill-71SS's Avatar
sounds like the trans controller went,it is under the pass.side carpet
Old Jun 27, 2004 | 09:25 AM
hondadude's Avatar
You can jumper the BLUE 2 pin connector and get the trans code via the flashing light. Then you can replace the speed sensor in the top of the differential.
Old Jun 27, 2004 | 11:23 AM
alb_accord's Avatar
yep change the speed sensor and see if u get more codes
Old Jun 27, 2004 | 07:37 PM
dcviperboy's Avatar
Default Re: (alb_accord)
same thing happened to a buddy of mine w/ his 93 accord, what do u mean by the trans controller, more info would b helpful, thx
Old Jun 27, 2004 | 08:44 PM
OK......I unhooked the battery for about an hour. Now the car is runnin fine..I guess it is a sensor that needs to be fixed. The s light is blinkin again but the car is changing gears as normal....I guess when I unhooked the battery it reset the sensor....Thanx
Old Jun 28, 2004 | 07:15 AM
dcviperboy's Avatar
I did the same thing on my buddys accord and got the same result, so i also assume i need a new speed sensor, but i called the local honda dealership on the price of the AT control unit and it was over 500 dollars, is there anywhere, if thats what i end up needing, that i can find this part cheaper, thx!! (will a junkyard part work?)
Old Jun 28, 2004 | 09:54 AM
alb_accord's Avatar
http://www.ebay.com they probably cost about $40
JDMCD5Accord95
Aug 29, 2013 08:20 AM
tondo45
Jan 30, 2006 02:56 PM
Hurricane
Sep 20, 2004 08:13 AM
4DRPIMPIN
Sep 26, 2003 12:16 PM
